588,069 active members*
4,787 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport torq-cut 22 1997 axis drive fault
    May 2014
    Hello all.
    Purchased a machine a cuple of months ago, started it, tested it, and it worked ok.
    Wife gets sick, no time to learn new machine, mice ate some of the wiring on the cabinet, problems begin for me.
    Patched the eaten wires with black tape.
    I start machine, hit f5 to go to maint. screen, Hit 7 to enable axis drive, get axis drive fault.
    See parameter 153, it goes 00000000, so no problem in no axis or so she thinks.
    hold down the spindle drive relay to see if the problem is there, drive starts and goes to 0. No fault code no nothing.
    That is what has been done so far.
    Can anyone Help?.
    C.
    Jan 2013
    11
    Re: Bridgeport torq-cut 22 1997 axis drive fault
    Did you do a continuity test on the affected wires? The mice may have damaged more than just the insulation. You need to use a multimeter to verify that each of those wires is still intact and capable of carrying voltage.
  1. Bridgeport Torq-cut 22 forgets its hard drive
    By Alley-Way in forum Bridgeport / Hardinge Mills
    Last Post: 10-16-2016, 04:37 PM
  2. X axis won't home? Bridgeport Torq-Cut 22 DX-32
    By hrhoward in forum Bridgeport / Hardinge Mills
    Last Post: 11-24-2013, 12:32 AM
  3. 1998 BRIDGEPORT EZPATH-S AXIS DRIVE FAULT
    By MRPMACHINE in forum Bridgeport / Hardinge Mills
    Last Post: 12-17-2011, 02:00 AM
  4. Bridgeport Torq-Cut 22 lost hard drive settings
    By oldcastletool in forum Bridgeport / Hardinge Mills
    Last Post: 10-26-2011, 10:23 PM
  5. Install of a Troyke 4th axis on Bridgeport Torq-Cut 22
    By RedGTZ in forum Bridgeport / Hardinge Mills
    Last Post: 10-15-2007, 03:10 PM
