586,070 active members*
3,430 visitors online*
Results 1 to 6 of 6
    Jan 2018
    3
    Bridgeport Vmc 500 Z axis problem
    Hi all,
    We bought Bridgeport VMC 500/16 machine and we have Z axis problem. Machine working property about 30 minutes and the problem appears randomly. We noticed that it happens most often when the Z axis is sliding down. She making whole in material and destroys head of the milling cutter. After that we have GROSS POSITIONING ERROR Z C (and number 6 on Z axis driver). Z axis brake is ok, but we think that he is disabled when machine is working and the Z axis driver has to stop Z axis but he couldn't. Speed regulation problem? Driver problem? we dont know.
    Our system: Heidenhain
    Z axis driver: 6SN1123-1AB00-0AA0
    Z axis motor: 1FT5064-0AF71-1-Z-1
    Has anyone had a similar problem?
    Thank you for your answers.
    Dec 2013
    5717
    Re: Bridgeport Vmc 500 Z axis problem
    Maybe an encoder problem?
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2018
    3
    We changed 1FT5064-0AF71-1-Z-1 motor on the same from another machine. The same error.
    Dec 2013
    5717
    Then must be the driver or encoder cable.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2018
    3
    Quote Originally Posted by Jim Dawson View Post
    Yes It was driver. I repaired him. IGBT module was ok but capacitors 150uF/400V were broken. I replaced them and everything is ok for now.
    Thank You for help.
    Special thanks to Jim Dawson.
    Jun 2011
    61
    Hi there , did you cure your problem ? I have a Interact 720 with the same problem on Z axis .This problem I had on Y axis and found out it was the infrared encoder was defect , the couplung has broke , replaced it and all was well , I hope this is going to be this easy ! Good luck Harry , in Bielefeld Germany
  1. Bridgeport VMC 560 Z axis and ool changer Problem
    By aiewolf in forum Bridgeport / Hardinge Mills
    Last Post: 07-11-2013, 04:17 PM
  2. 1995 Bridgeport 760-22 X axis home problem
    By eric14779 in forum Bridgeport / Hardinge Mills
    Last Post: 04-26-2013, 06:42 PM
  3. Bridgeport Powerpath X axis problem
    By amgearinc in forum Bridgeport / Romi Lathes
    Last Post: 06-06-2011, 04:56 PM
  4. Z-axis Problem Bridgeport CNC serie 1
    By Rufan in forum Bridgeport / Hardinge Mills
    Last Post: 08-10-2005, 02:31 AM
  5. How To; troubleshoot an Axis problem on Bridgeport BOSS
    By inthedark in forum Bridgeport / Hardinge Mills
    Last Post: 03-25-2004, 02:35 PM
