603,832 active members*
4,324 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport VMC760/20 Z axis not positioning correctly for tool change
Results 1 to 6 of 6
    Aug 2007
    3
    Question Bridgeport VMC760/20 Z axis not positioning correctly for tool change
    Hi Yesterday we had a blackout in the factory and i was worried that it may have affected the parameters of the machine. I shut the machine down completly until i was sure that we had full 3phase power again! When I turned it back on all seemed to be ok and the machine ran without fault for the rest of the day! At the end of the day i shut it down as per usual and then this morning when i started it up all seemed to be fine, it zero returned and has not thrown up any alarms or errors! It was'nt untill I tried to manually tool change to set up nex job that i noticed that Z height had not gone to correct position to execute the tool change! It was aprox 60mm low and the tool holder forks would have smashed into the side of the head had i not noticed it! Now I am pretty sure that it will be a parameter problem somwhere but am not sure how to go about rectifying this problem! Any help would be greatly appreciated! Also i should add the machine has a Heidenhain tnc 2500b controller
    Nov 2004
    3028
    resetting the tool change height procedure (including the parameter)should be in the maintenance manual. I have a classroom book that is at the office that should have this data as well but I have not been there in over a week. Have you tried a cold boot and rehoming it again?
    George
    Aug 2007
    3
    thanx
    thanx for you reply. i had tried many different ways including a cold start and rehoming but with no success. I'll go through the manual again and hopfully have a bit more success! thanx for the reply!
    Feb 2006
    992
    more likely the approximaty switch sensor is worn out or the laser eye sensor is not sensortive anymore...... it need to be replace
    The best way to learn is trial error.
    Dec 2003
    24260
    60mm is probabally well out of the axis grid shift parameter, if the tool change position is the zero position of the Z, then it sounds like something shifted on the zero slow down dog for the Z axis.
    Al.
    Albert E.
    Nov 2004
    3028
    Attached, I found a tool change sequence showing relevant parameters, and input/outputs.
    George
    Attached Files Attached Files
  1. Alarm during Tool Change on Bridgeport 320H
    By ChrisB in forum Bridgeport / Hardinge Mills
    Last Post: 02-10-2014, 03:49 PM
  2. EMC2 Axis Manual Tool Change
    By tomdoyle in forum LinuxCNC (formerly EMC2)
    Last Post: 08-09-2010, 02:46 PM
  3. Z positioning after changing tool (sequencial engraving)
    By gravosfera in forum Engraving Machines
    Last Post: 05-13-2007, 08:25 AM
  4. Replies: 2
    Last Post: 11-27-2006, 06:38 PM
  5. Boss 5 X axis positioning
    By kewl_cat in forum Bridgeport / Hardinge Mills
    Last Post: 01-07-2006, 05:04 PM
