603,385 active members*
3,223 visitors online*
Results 1 to 15 of 15
    Feb 2007
    11
    Broaching on CNC Mill?
    Is it possible to use something like a rotary broach with a CNC Mill to make an internal hex?
    Here is some of the background info. Normally I just make a hole and take the parts to another company to have them pull broached, but is it possible for me to use something like a rotary broach in a cnc mill? The material is usually something comparable to a 1020 steel (Martin off the shelf gears) that I have to machine and then they get broached. The parts have between a .375 - .625 flat to flat hex that goes through about .375 thick material (thru hole not blind). I would be doing this on a VF1. Are there any other cost effective ways to do this without spending large amounts of money or sending the parts out for EDM or broaching?
    Sep 2006
    607
    We actually do this at work with a large Index lathe, so it would seem possible to do the same thing on a mill.
    Jun 2008
    130
    Drill a hole at each vertex to make the corner radius, drill & bore the biggest hole that will fit, mill the rest?
    Mar 2006
    2712
    tkoden, Read the stuff at www.sommatool.com
    They mention using on CNC machining centers and mills.
    Dick Z
    DZASTR
    May 2008
    72
    Try these guys
    http://www.slatertools.com/
    JP
    Nov 2004
    65
    re: Rotary Broaching on CNC
    This rotary broaching video shows a 3/8" hex being cut on a lathe.
    The tool holder will work on a CNC mill by turning the holder instead of the material.
    [ame="http://www.youtube.com/watch?v=lcTJKySDDx8"]Rotary Broaching[/ame]
    Sep 2006
    607
    Thats the exact same tool we use on our index lathes! Easy to use, and fast. Might need a big and rigid machine, but should work.
    Feb 2007
    11
    Quote Originally Posted by peter@slater View Post
    Rotary Broaching
    How rigid of a machine do you need to be able to do this? Is a VF1 going to be strong / stout enough to do this?
    Nov 2004
    65
    re: VF1
    According to the Slater catalog, 1/2" hex broaching in 12L14 generates about 850 thrust lbs., I'm not sure if the VF1 can handle that. I read online it has up to 250 ft.lbs. of torque.
    There is another important issue to consider: When rotary broaching, the spindle inside the tool holder spins freely. When contact is made with the part, no orientation is provided. If alignment of the flats of the hex to the part is required, you may have to fixture a broaching 'dog' to align them.
    Nov 2004
    65
    re: Broaching in a Mill?
    This video shows Rotary Broaching in a Mill. Stop Rods are shown mounted on the spindle side or work side. The orientation dog is used for alignment of the broach to the work piece.
    [ame="http://www.youtube.com/watch?v=BVBrbeQgfHI"]YouTube - Slater Tools Orientation Dog Video[/ame]
    Nov 2005
    160
    FWIW, the spindle torque rating (250 ft-lb) has nothing to do with the required thrust force (850 lb)... One is a torque, the other a force...
    I have no idea how much thrust the axis can generate but am pretty certain it is over 850 lb. It's all dependent on the axis servo torque and ball screw specs / size.
    Feb 2006
    58
    We use a rotary broach in a smaller VMC... no problems... one trick we use to make it completely painless in harder materials is to drill then tap the holes first...
    Nov 2004
    65
    re: tapping
    Nice trick yadda, probably makes smaller chips too.
    May 2011
    37
    Help !!! I looking for rotary broaching holder used...
    hi... I am new in this forum. I would like to purchase a rotary broaching holder used, because I cannot afford a new holder, too much expensive..
    can you help me if you have news of shops or people that sell?
    Mar 2011
    Rotary Broach Tool Holder
    Quote Originally Posted by walkit View Post
    Hello:
    Not sure if this helps but Polygon Solutions will rent you a rotary broach tool holder for $100 for 30 days. For more details visit: Rotary Broach Tool Holders
    http://www.polygonsolutions.com
  1. Rotary Broaching
    By rhino in forum MetalWork Discussion
    Last Post: 09-16-2011, 07:15 PM
  2. mazak integrex broaching
    By precisiontork in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-27-2008, 01:57 PM
  3. Which press for broaching?
    By Arnaudb in forum MetalWork Discussion
    Last Post: 03-30-2008, 02:19 AM
  4. Turning and broaching needed
    By fredhh47 in forum Employment Opportunity
    Last Post: 01-23-2008, 04:52 PM
  5. Broaching advice
    By Al_The_Man in forum MetalWork Discussion
    Last Post: 12-19-2006, 12:03 PM
