I've been planning to use Brother HS-70A EDM for some of my projects but I came up with a problem with edge and center detection. The machine was built year 2005 and it's operated only for 1k hours.
Fault description: The machine runs otherwise fine but the edge detection and centering does not function. The machine indicates a contact no matter what I try.
I cleaned the machine properly and it didn't solve the problem. After contacting the Brother sales in US I received a diagnostic procedure which indicated the problem is with electronics. According to the diagnostic procedure unplugging a certain cable should disconnect the mechanical parts (which might be grounded) from the measurement circuit.
The problem is difficult because the damaged electronic board is expensive. The repairs costs about 5000 euros and the board has already been replaced once. The edge detection and centering worked for a day after the card was replaced and then the same problem repeated. Manufacturer does not give any warranty for the replaced electronic cards and the reseller hasn't been very helpful in solving the problem.
I've taken some measurements of the machine with a scope and during the edge detection I can record a 50kHz +-10V signal from the upper cutting head. The signal disappears if the wire is in contact with a work piece. I've assumed this is the signal the machine uses for probing the edge. As there is a signal I'd guess the problem is with the measurement of this signal but I this is really guessing...
I also pulled out the damaged card from the machine and checked all the connections. This didn't solve the problem either. The only thing I noticed was that there were more than ten components added on top of the SMDs by hand soldering and by using hot-setting adhesive. They are close to the part of the PCB where the "edge detection cable" ends. This might lead to a conclusion that there has been some problems with electronics and the manufacturer has tried to solve the issues by adding some components afterwards.
If somebody has had similar problems with this machine and has been able to solve them in some way, I'd highly appreciate any comments which might lead to solving this problem. As I'm working at a university we are always a bit short of money and we cannot really afford another 5k repair for the machine especially if the problem is not solved.
Regards,
Jari
