603,380 active members*
3,576 visitors online*
Thread: BT Tooling
Results 1 to 7 of 7
    Apr 2014
    188
    BT Tooling
    G'day guys,
    I've got a 1100-3 and I'm going to buy a 1500MX.
    I'm sorting through my tooling, to see what I need in BT30.
    I've got a 3/4" (TTS) Shear Hog and it's been really handy, but what do I use in BT30?
    Same for the Super Fly cutter... any suggestions.
    Michael
    Re: BT Tooling
    What about using a regular BT30 collet chuck?
    Apr 2014
    188
    Re: BT Tooling
    Hi and thanks for the reply.
    As I mentioned, I've never worked with BT30, but that seems like a lot of "stick out".
    Is that the easiest way or can you buy a BT30 fly cutter?
    Michael
    Nov 2013
    5405
    Re: BT Tooling
    I'm not familiar with BT30 either, however I've in recent months bought a new spindle that has an HSK32 tool interface....so I've been learning about tool holders also.
    Most face mills require an arbor. So, the most common way is to get a BT30 arbor, say 1". Then buy a face mill that fits that arbor. A 2" face mill would be a good fit
    with a 1" arbor. This is an example:
    https://www.ebay.com/itm/30496146653...Bk9SR8CzpOSFZQ
    Note how there are two separate pieces, the arbor and the face mill. It may well be that you have one arbor but several face mills.
    I bought an HSK32 3/4"arbor and a Valenite 11/2" face mill and it works well. Needed specialist inserts, which I did not know at the time. Found a local supplier (New Zealand)
    who was able to import the required Widia inserts and got them within a fortnight. Sort of saved my bacon. Would have been pretty annoyed with myself that I bought a face mill for
    which I could not buy inserts.
    Craig
    Apr 2014
    188
    Re: BT Tooling
    Hi Craig,
    The beauty of the Super Fly is it's adjustability and you can fly cut nearly 3".
    I already have a 2" cutter, but I was trying to find something bigger.
    The cutter (that you put in the link) is one that I've already got, but thanks for the effort.
    Michael
    Nov 2013
    5405
    Re: BT Tooling
    then buy a 3" shell face mill that fits the same arbor.
    Craig
    Jun 2005
    659
    Re: BT Tooling
    I went through this with an 1100MX. You can get a BT30 3/4" endmill holder or ER32 collet chuck to hold TTS tools, but it's sub-optimal with that much stick out and places for tolerances to stack up. For face mills I'd get a size and weight that's reasonable for the machine. IDK what Tormach's spec is but HAAS says no more than 7" stickout, 5lbs and 2" cutting diameter on their BT30 DT1/2 machines. HAAS sometimes puts BT30 stuff on sale and it's on the upper-end of China-quality tooling. Maritool is where I go for nicer tools.
    Oddly small drill chucks and JT arbors are also not common in BT30 as it seems the default for BT30 is ER tool holders for most everything.
  1. Replies: 0
    Last Post: 09-22-2015, 07:39 PM
  2. Replies: 0
  3. Replies: 4
    Last Post: 05-07-2012, 12:54 PM
  4. punch tooling,cnc punch press tooling
    By sentool in forum News Announcements
    Last Post: 10-04-2011, 04:26 AM
  5. Replies: 2
    Last Post: 08-09-2010, 04:17 PM
