587,228 active members*
3,651 visitors online*
    Mar 2011
    3
    Build research?
    I would like to be able to add a trunion table to my build. I won't use this often but want the feature. I don't want a huge z azis to accomadate the extra height so I thought of being able to lower the table height in the middle by removing the deck and bolting the table to a lower frame?
    Problem is if I build a gantry with a cross beam it will make contact with the lowered trunion table.
    The fix would be building with two actuators on the X axis?
    How do you control the servos to run exactly in sinc? so it doesn't jam?
    Is there a better way?
    Thanks! Great board lots of info!! I feel like a sponge!
    Oct 2004
    590
    The controller software takes care of the sync.
  1. Best CNC for a research lab
    By cqed in forum Benchtop Machines
    Last Post: 04-11-2012, 02:32 AM
  2. New Guy Doing Research
    By SmokinPRanch in forum Torchmate
    Last Post: 11-14-2010, 04:00 PM
  3. HSM research
    By katebao in forum Hard / High Speed Machining
    Last Post: 12-18-2007, 04:25 AM
  4. project research
    By ramus in forum CNC Wood Router Project Log
    Last Post: 10-26-2006, 02:59 AM
  5. Market Research
    By Andy NC in forum Uncategorised CAM Discussion
    Last Post: 07-20-2004, 10:11 PM
