Hello All!
I've got to wire and configure 4axis cnc machine to work with kflop.
What I have:
- 3 NEMA34 1200 oz-in Stepper Motor - Dual Shaft (KL34H2120-42-8B) (Y, Z, A axis), wired Parallel
- 1 NEMA34 Stepper Motor – 906 oz in 6.1A Dual Shaft (KL34H295-43-8B) (X axis), wired Parallel
- 1 Unregulated Linear 1440W/72VDC/20A Toroidal PSU (KL-7220) (measured 64V idle, connected serially to 220VAC)
- 1 KL-34GH101 10:1 Planetary Gearbox 4000RPM (A axis)
- 4 Gecko G201X (10uSteps, 3.3V common, configured 3A)
- 6 NPN DC6-36V LJ12A3-4-Z/BX as home/limit switches. Powered from 12V and connected to Kflop through resistive simple voltage divider (3.1V after devision)
- 3 Omron e6b2-cwz6c (npn). Signal wires ground connected through 1kOhm resistor.
- 4kW spindle (3 phase)
- TOSHIBA VFS11-4075PL-WN VFD (want to control it with ModBus RTU from Kflop)
- DLS-B1600 linear glass scale (X axis)
- Rigol scope to help in finding issues
- bunch of resistors and capacitors
Photos of build-in-progress
What does work (more/less):
- axis movement more/less. Because acceleration/velocity is not configured properly yet.
- home/limit switches. There are false positives sometimes on Z axis.
- some output from OMRON encoders (linear glass is not connected yet). But because they are NPN and not PNP the output signal is inverted because of the way I connected them
I'm using latest version of KMotion (4.33l). Problems so far:
- Pressing Save/compile/download/run doesn't make any difference from time to time. At least changes are not reflected in step/response measurements. Flashing usermemory + Kflop reset does make change.
- Most of chX-> params are unclear to me. Like:
* Lead=0
* invDistPerCycle=1
* MaxOutput=5000
* MaxI=5000
* FFAccel=0
* FFVel=0
- command and measure are weird to me (at least now). What I've got yesterday when connected encoders:
Red line and axis values at the left as weird to me.
- for some unknown reason channel 2 stopped working for me 2h ago.
My config so far is attached.
I would appreciate any help. Thanks!
