I am prepairing for build spindle for small grinding machine. Axial forces will be in both directions. I found this drawing. I would like remove tube which is between inner rings. This get me possibility for change bearing preload (ball bearing with angular contact) during the use. Is this acceptable? Maybe this tube have any influence on rigidity of spindle?
regards,
Promehanik
