603,870 active members*
3,263 visitors online*
    Dec 2006
    116
    Building with supported rails?
    I´m thinking on building a machine with supported rails from Motion control products http://www.motioncontrolproducts.co....products_id=93
    But I was told that these should not be used in any other position than horizontaly
    And I think I have seen several machines that have used rails like these in every axles.
    So the question is, how does these work vertical, or on the side?
    May 2006
    168
    I have not heard of these not working except for horizontal position. Was there a reason? I know they have different load capacity base on the direction of the load with respect to the rail.
    I would be interested in any information on the working positions for these.
  1. who sells fully supported rails?
    By SatanKlawz in forum Linear and Rotary Motion
    Last Post: 06-20-2012, 09:06 PM
  2. 16mm vs. 20mm supported linear rails...
    By WilliamD in forum DIY CNC Router Table Machines
    Last Post: 12-20-2008, 12:37 AM
  3. G1 with R - not supported?
    By padobranac in forum NCPlot G-Code editor / backplotter
    Last Post: 10-13-2008, 06:35 PM
  4. Which G-codes supported?
    By John3 in forum Fanuc
    Last Post: 04-02-2007, 10:51 AM
  5. Where can I find supported shaft?
    By Cold Fusion in forum DIY CNC Router Table Machines
    Last Post: 12-19-2004, 04:49 AM
