588,240 active members*
4,277 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Burn Table Lead Out of Zero ERROR
    Dec 2005
    19
    I wanted a Lead Out of 0.00 which shoud be fine.
    Bobcad doesn't see it as a Lead Out of 0.00 it
    see it as NO LEAD OUT. Which in turn doesn't turn of the gas
    and cuts a line in the part and turns it to scrap.
    This is an ERROR or there should be a NOTE: Lead Out of 0.00
    will etc...
    Later JeReMy
    Mar 2012
    1570
    Post Settings
    JINDA,
    What post are you using? I get a "m code " for off and on if I use a lead in / out or just a lead in...
    Can you post a sample file and or your post processor?
    Al
    Attached Files Attached Files
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Dec 2005
    19
    Thanks Got it.
    The error is in the post
    Later JeReMy
  1. 203 lead screw error .007" work shift
    By duckslayer in forum Haas Mills
    Last Post: 01-10-2012, 03:56 AM
  2. lead screw diameter for 6 ft table
    By tkms002 in forum DIY CNC Router Table Machines
    Last Post: 03-27-2011, 07:19 AM
  3. Lead error?
    By Schwabie in forum Bridgeport / Hardinge Mills
    Last Post: 10-15-2008, 02:05 PM
  4. Roton Ballscrew Lead error figures?
    By davo727 in forum Linear and Rotary Motion
    Last Post: 03-17-2007, 11:19 PM
  5. Compensating for ball screw lead error?
    By Noah in forum Uncategorised MetalWorking Machines
    Last Post: 08-13-2004, 02:51 AM
