Before I begin, I'd like to clarify- this is a sort of continuation/addendum thread of Zoidberg's amazing "backlash free rotary table" thread (see http://www.cnczone.com/forums/showthread.php?t=72261). I don't mean to hijack it, and I have more specific questions/breakdowns for my posting, so I decided to try a new thread.
I'm about to buy a Taig manual mill, and I want to do a lot of gear hobbing- so I need a rotary table. Carter tools sells Sherline rotary tables for about 250$. Money isn't a total issue, but I'm not rich. I figure, I've got about 1200-1300 dollars to work with for everything.
Thing is, I plan on cutting very small gears, with extremely high tooth counts, and various other items like time equation cams for clocks where standard rotary tables may work, but I want to kick it up a notch. I plan on working with large gear trains (making full orreys, etc), so even the smallest backlash or positioning error of a normal table isn't acceptable, or the cumulative error will add up over time and ruin the orreys. So I'm thinking of building a rotary table. An exceptionally precisce one, with NO backlash. None.
Put aside for a second what I've said, forget that material tribology will change over time and wear the gears anyway, and other concerns. Just work with me here and dream.
I can afford that Sherline rotary table. But it's not as positionally repeatable and as backlash free as I need. Reading Zoidberg's amazing post, and everyone's comments meticulously, I've decided to repost all the positioning technologies discussed therein here, named, numbered, and with relevant links.
So here's what I ask from anyone who knows them: Can you comment on these things:
A. Cost - how much to buy the components/system, typically?
B. Precision - how repeatable is the the positioning tech?
C. (most important) Fabricability - how feasible would it be for someone to create this in the shop with only a 3 way mill, and NO rotary table? (Or with a standard rotary table as an initial investment?)
1.Worm gear (I'm not really considering this- traditional worm gears have too many shortcomings for a single one to work well for my needs)
2.Dual worm gear (http://www.allytech.eu/index_fichier...dwormwheel.htm)
3.Duplex Worm Gear (http://en.wikipedia.org/wiki/Duplex_worm)- this one's interesting.
4.Harmonic Drive- sounds promising, but the cheap ones are HUGE. I need something I can fit on a Taig mill!
5.Pneumatic Drive (air bearing, ala Onvio’s Dojen Cycloidal Speed Reducers) (http://www.onviollc.com/dotnetnuke/C...Default.aspx)- these look especially promising.
6.Hydrolic Drive (oil)
7.Rack & DUAL Pinion (http://www.globalspec.com/FeaturedPr...lDrive/74196/0)
8.Howimatt Recirculating Ball Drive (Epicyclic Gear)(http://www.detlevhofmann.de/english_.../funktion.html)
9.Hypocycloidal Reducer (http://www.zincland.com/hypocycloid/) Ala user ZincBoy, and the incredible creations of him and others, such as in beautiful metal ala user LaRdArms ([ame="http://www.youtube.com/watch?v=cnJCWX2nr4M&feature=channel_page"]YouTube - hypocycloid reducer[/ame]) These look like the most doable on a mill, with great possibility for really high accuracy. These also include versions that incorporate ball bearings.
10. Ball Worm Transmission (http://urobotics.urology.jhu.edu/projects/BW/)
This looks the simplest to me, and also very buildable.
11. Anything I missed not previously discussed, however outlandish or exotic.
Final caveat- I want to do this manually. I enjoy hand machining, and don't see the fun in CNC for what I do. I want to make something that is hand cranked. I can always add a servo later, the idea here is for manual operation, let's concentrate on the bare mechanics of it.
Keep in mind, I need this to fit on a Taig mill. It's not a gigantic rotary table I need. Large diameter is great- excellent in fact, but height not so. I can fit a large diameter of 6-7 or maybe even 8 inches on the Taig table, but nothing very high. Let's try for 3 inches or so tall. It won't be handling large amounts of weight or torque, and I'd like to be able to adjust backlash if possible, to allow quick rotation, but able to lock back in precision rotation as needed.
Let the brainstorming begin!
