587,215 active members*
3,199 visitors online*
    Feb 2007
    314
    buying a new vmc Mori vs Okuma
    we are going to buy a new VMC and at this time two machine are in the race. First one Mori seki Dura vertical 5100, second Okuma genos M-560-V. No experience with this two brand. We only cut aluminium and tolerance are large enough (+-.005" usually) So extra precision, is not a critical point. Here is the pro and con that I see for this two machine, hope you will add some point that i did'nt think.
    Mori:- Fanuc control (I'm familiar with fanuc and we have another VMC that is fanuc controlled)
    -same taper, same pull stud than our other vmc so toolling is fully inter changeable.
    -Midaco pallet changer come with the machine and with the mori waranty(twice the Midaco waranty)
    Only 12 000 RPM spindle
    spindle motor is half the power of the Okuma.
    Okuma: -Faster rapid feed
    15 000 rpm spindle
    -twice the spindle power than th mori
    -big plus spindle come standard
    -axis motor more powerfull
    -dual column desing supposed to be more rigid and accurate over a C-frame.
    -added high presure coolant and auto porobing and tool lenght measurement and still less expensive than the mori without this options
    -okuma control(that i know nothing about)
    -tooling not fully interchangeable with our other vmc(same taper but not same pull stud)
    -Pallet changer must be purchased appart tough machine supposed to be ready to accept midaco pallet changer.
    Actually, i tought that the okuma will lead the race, but maybe you can higlight some point that can change evrything.
    thank you
    Apr 2012
    141
    Re: buying a new vmc Mori vs Okuma
    which one did you go for in the end ?
  1. Replies: 10
    Last Post: 04-14-2014, 07:43 AM
  2. Replies: 6
    Last Post: 11-05-2013, 11:50 PM
  3. Buying Mori NT
    By Green Button in forum Mori Seiki lathes
    Last Post: 12-10-2012, 03:09 PM
  4. Buying OKUMA MA600HB
    By Green Button in forum Okuma
    Last Post: 02-20-2012, 07:15 AM
  5. Okuma-Mori or Mori Dura
    By KKM in forum Okuma
    Last Post: 11-09-2010, 12:43 AM
