588,585 active members*
13,538 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > C Axis Motor Overload
    Aug 2007
    29
    Looking for suggestions. This message (overload) is easily cleared, and production resumes.
    1.) It is random, sometimes going 3 shifts or more before occurrences.
    2.) The program code is using S.1 and S.2 commands.
    3.) I have replaced the inverter (Yaskawa G2) with an Advanced Motion Control unit.
    4.) Checked connections on card 14
    5.) Replaced spindle encoder earlier this year.
    6.) Checked motor resistance.
    I can't seem to generate an overload by MDI of speeds and belts. It happens when running programs, and randomly so. Thanks.
    Aug 2007
    29
    Update-moved the spindle command onto a line of its own (ex-M3 S3000.2) the machine ran uninterrupted for the evening shifts. Is there a setting in the control,like look ahead,that is effecting the spindle getting the command, and having enough time to respond, before the control moves onto the next block? A low voltage in the command signal for this new(er) drive?
  1. Error 55 motor overload (T1)
    By carbidecraters in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-27-2019, 01:05 PM
  2. Y-axis overload
    By cdlenterprises in forum MetalWork Discussion
    Last Post: 04-21-2007, 11:03 PM
  3. spindle motor overload
    By RdHawg in forum Uncategorised MetalWorking Machines
    Last Post: 12-06-2006, 08:02 PM
  4. Help!!! Y axis overload won't go away
    By soweebee in forum Bridgeport / Hardinge Mills
    Last Post: 06-15-2006, 03:15 PM
  5. TC-22 Z-Axis Current Motor Overload
    By PPM in forum Bridgeport / Hardinge Mills
    Last Post: 08-11-2005, 07:09 PM
