603,388 active members*
2,782 visitors online*
Results 1 to 10 of 10
    C6 Threading.
    Hey guys.
    Would love to hear from people that are successfully using their C6 for threading and if they can share their tips, settings etc.... This would really help everyone out their that are having trouble getting their C6 to thread correctly.
    thanks in advance.
    cheers
    Frans
    Toolmach
    Apr 2007
    157
    Threads
    Quote Originally Posted by ToolMach_Aust View Post
    Hey guys.
    thanks in advance.
    cheers
    Frans
    Toolmach
    hey there;
    Here is a zip file...if it made it
    I have cut many thds. on the C6 use the wizard in Mach3 Turn and enter the numbers. if you are using inserts(prefered)or a HSS tool make sure every thing is indicated straight. I prefer to "0" Z at the face of the Part and stay .015 away from sholders. Toutch X on the part O.D. enter dia in DRO on Manual Screen>3/8-16 .375 Major dia. "0" part DRO. Zero Z too!
    Your Start X dia is .375
    Your End X dia is .293
    The rest is whatever your Part length is ect.
    The Turn wizzard will do the rest.
    I have always used 3wire method to measure the thds. and it has always been +/- .001-.003. Works good enough for what it is.
    The Threads zip file saves much time. with the numbers. Bob
    Attached Files Attached Files
    May 2005
    925
    I made this video showing the C6 in threading action time ago:
    http://video.google.com/videoplay?do...05157483&hl=en
    Pablo
    Journeyman.
    Thanks...
    A client of ours is having trouble with threading. The threads start fine and then the pitch seems to change further along the thread. Not sure if Mach3 is reading the Spindle Speed correctly?..
    Are there any special settings in Mach3 for the spindle. What are your spindle settings.
    cheers
    Frans
    Quote Originally Posted by Journey_Man View Post
    hey there;
    Nov 2005
    145
    If each succeeding pass is starting in the same place on the workpiece then the index sensor is probably being read properly. This is the most important synchronization required for a typical short thread. - rpm is secondary. If the threads are getting closer together as you go further down the workpiece then the problem may be that you're not starting the tool far enough away from the workpiece to allow it to accelerate up to a constant velocity before it starts cutting. Mach3 should be checking for this and issue a warning before you start, however. If none of this solves the problem and the thread is long or if for some hardware reason the spindle speed is varying too much then you can go to the Config menu ->ports&pins -> spindle setup. There should probably be check in the "Use spindle feedback in Sync Mode' and in "spindle speed averaging.' If this is OK then you might try also placing a check in the 'Closed Loop Spindle Control.' No one really seems to know what to do with the PID parameters and so leave them at their defaults of .3,1,.3. I don't own a C6 but I do own something very similar and threading really does work in MAch3. Run at a very low rpm - I use just over 300 rpm (the bottom end of my spindle motor controller's capability) - so the carriage can keep up with the spindle for your typical range of thread pitches. - Terry
    May 2005
    925
    I just made this more detailed video of the C6 threading in action:
    [ame="http://video.google.com/videoplay?docid=5557473837334990194&hl=en"]Syil C6 Threading 2[/ame]
    Pablo
    Nov 2005
    145
    Well, the OP's question turns out to be pretty timely. If you've been reading the discussion on threading over on the Mach forum, it turns out that threading is broken in the current Mach release and has been for sometime -how long is anyone's guess. I'm running version 2.42 and in that version it works fine. Sometime after that release, however, a change was made to the milling side of Mach to improve drilling cycle speeds and this change rippled into Turn and broke the threading functionality. The reported symptoms seem to vary from incorrect pitch to just just really ugly threads. Art claims to have tracked down the problem and believes he has fixed it for a pending release which should be any day now. There hasn't been a development release for several months, which is really unusual for Mach and the developer(s) have been busy cleaning up a number of long standing issues. Hopefully they didn't break anything else of significance along the way. - Terry
    May 2005
    925
    can you provide the link to this thread at mach3 forum? Thanks!
    Nov 2005
    145
    Start here for the solution. There is a long thread previous to this describing various user symptoms.
    http://groups.yahoo.com/group/mach1m.../message/96103
    May 2004
    61
    Hi
    A drifting pitch in Mach3 is usually a sign of running in demo mode. Make sure your license file is in th Mach3 Directory.
    Deon
  1. G76 threading
    By Kai_DK in forum Fanuc
    Last Post: 08-08-2018, 11:03 AM
  2. Threading MDF
    By Me2 in forum FAQ of DIY CNC Machine Building
    Last Post: 05-26-2011, 06:08 PM
  3. Threading on a SKT 21 LM
    By JohnBV in forum Hyundai Kia
    Last Post: 06-10-2008, 07:02 PM
  4. Threading with G76
    By cijunet in forum Mastercam
    Last Post: 12-19-2007, 01:43 AM
  5. threading
    By wrenchcruncher in forum MetalWork Discussion
    Last Post: 01-27-2007, 01:40 AM
