587,221 active members*
2,955 visitors online*
Results 1 to 10 of 10
    May 2007
    11
    Unhappy C62 quit responding....
    Hello all,
    I hope one of you guys can assist me. Went to fire up the machine today and... no response at all from the C62. The ESS is responding and verified through its data monitor. All the voltages check out on the C62, including the 5vdc out. The only C62 LED I get is the power. Any thoughts on this?
    Thanks guys,
    Chris
    Attachment 361926
    Re: C62 quit responding....
    Chris,
    Tell me more:
    - Do you get the power LED?
    - Standby LED?
    - Does it activate (Enable LED)?
    - Do you see action on inputs in the Data Monitoring Utility?
    Arturo Duncan
    Welcome to CNC4PC
    May 2007
    11
    Thanks for the speedy post Arturo. Here's what I've got:
    Power LED - Yes
    Standby LED - Nope
    Enable LED - Nope
    As far as the inputs, I've got the ESTOP strapped out. Although, when I remove the jumper I get nothing.
    Let me know if that's what you were after.
    Thanks,
    Chris
    Chris,
    Can you test other inputs? Maybe limits?
    What happens if you disable the Safety Charge Pump? DIP2=off.
    Arturo Duncan
    May 2007
    11
    Arturo,
    I will test some inputs later today and let you know the results. As for the charge pump, I wasn't running one before so it has always been turned off. The photo I attached in my first post is with the board powered up. The led's are very difficult to see in the photo, sorry.
    Thanks Arturo,
    Chris
    May 2007
    11
    Good morning Arturo,
    Well, I have no good news. I tested multiple inputs as well as all the available outputs I had left, and unfortunately got no response on any. The inputs are not getting back to the ESS data monitor and the outputs are being reported on the ESS monitor but not making to the C62. Bummer, what do you think?
    Thanks Arturo,
    Chris
    May 2007
    11
    Arturo,
    I decided to pull the ESS and C62 to bench test it with a different 12vdc power supply. I took some voltage readings at most of the chips and they are seeing 4.97vdc. Upon inspection with a magnifying glass, I found something of a concern...
    Attachment 362012
    Looking closely at the Atmel MCU, there appears to be substantial corrosion between many of the pins...
    Let me know what you think.
    Thanks,
    Chris
    Chris,
    This does not look good. Please open a ticket in our website and we will replace the board:
    https://cnc4pc.com/contacts/
    Arturo Duncan
    May 2007
    11
    Hello Arturo,
    Thanks so much for your assistance. I'm not sure if I opened the ticket correctly but I do have this number for you: YJT-05491
    Let me know how you would like me to proceed.
    Thanks again,
    Chris
    May 2007
    11
    Just wanted to post a follow-up message to all reading this thread. Arturo is in the process of shipping me a replacement C62 board. I just want to say that all of my dealings with CNC4PC have been nothing but pleasurable. I understand that weird things happen (especially in electronics!) but Arturo is taking care of it.
    Thanks Arturo!
    Chris
  1. Need Help laser has quit
    By durham79 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-13-2015, 05:39 AM
  2. Run from here quit working
    By chasxjs in forum Mach Plasma / Laser
    Last Post: 10-03-2014, 02:45 PM
  3. Mach3 quit responding
    By wayja in forum Machines running Mach Software
    Last Post: 03-07-2013, 03:31 AM
  4. KM3 quit, mid-cut
    By jbmozer in forum HURCO
    Last Post: 08-22-2011, 10:15 PM
  5. V22 Quit Running
    By TZ250 in forum BobCad-Cam
    Last Post: 02-14-2008, 02:06 PM
