587,872 active members*
3,711 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > DNC Problems and Solutions > Cable for Fanuc Control to a 16 port Rocket Port
    Jan 2014
    I need to connect mutiple Fanuc Controls CNC machines to a 16port RocketPort, if I connect the 25pin connector to the cnc and the 9pin to the computer directly I can move data back and forth, plugging the 25pin cnc machine into the 25pin rocketport does not function, My rs232 tester shows different lights for the rocketPort, is there a pinout or special cable I need to use to make this function correctly? Any help would be appreciated.
    Rich
    Mar 2003
    2932
    A 25-25 cable crosses pins 2 and 3, a 9-25 cable doesn't.
    DB25(NC) <-------------> DB25(PC)
    1 <----- shield ----- no connection
    2 <-----------------------> 3
    3 <-----------------------> 2
    7 <-----------------------> 7
    4 & 5 jumpered (NC side only)
    6, 8, 20 jumpered (NC side only)
    DB25(NC) <--- ---------> DB9(PC)
    2 <-----------------------> 2
    3 <-----------------------> 3
    7 <-----------------------> 5
  1. parallel port cable
    By spaltiel in forum DIY CNC Router Table Machines
    Last Post: 04-17-2010, 03:10 PM
  2. usb parallel port cable
    By shadowless in forum Machines running Mach Software
    Last Post: 01-02-2010, 02:07 PM
  3. MC433G & cable for LPT port M-M
    By looseman in forum Stepper Motors / Drives
    Last Post: 11-17-2009, 02:36 AM
  4. serial port cable configuration
    By beno in forum DNC Problems and Solutions
    Last Post: 10-29-2008, 05:30 AM
  5. port cable check
    By cook in forum Machines running Mach Software
    Last Post: 01-29-2008, 07:25 PM
