587,143 active members*
4,635 visitors online*
    Jan 2015
    23
    cabochon drilling machine
    Main Parameter:
    Voltage: 220V
    Power: 650W
    Dimension: 480*400*670mm
    Weight: 26kg
    Working frequency:15kHz-20kHz
    Drilling diameter: 0.6-6mm
    Drilling depth: 0-30mm
    Function:adopt approved design for stable operation and long term usage. It's special for precise drilling of individual stone.
    www.dongtai168.com www.dongtai1688.com
    gem processing machine
    Apr 2004
    5740
    Re: cabochon drilling machine
    Does this have a quill handle, like a drill press, that's not shown? Or does it descend at the press of a button? Is that a water-dripper to the right?
    Andrew Werby
    Website
  1. Replies: 1
    Last Post: 06-16-2014, 08:15 AM
  2. PCB Drilling Machine suggestions.
    By mrpackethead in forum PCB milling
    Last Post: 03-12-2013, 03:32 AM
  3. The Best Gun Drilling Machine
    By atrus9999 in forum Uncategorised MetalWorking Machines
    Last Post: 04-26-2011, 10:04 PM
  4. Which Drilling Machine to Use?
    By Deedo in forum DIY CNC Router Table Machines
    Last Post: 01-07-2011, 10:02 PM
  5. Milling/Drilling machine
    By Ken_Shea in forum Uncategorised MetalWorking Machines
    Last Post: 12-02-2004, 06:22 AM
