588,093 active members*
4,447 visitors online*
Results 1 to 10 of 10
    Apr 2006
    65
    CAD/CAM recommendation
    I have a 3 axis CNC mill and currently using Mach 3 to control it. I have no CAD/CAM software so I have just been using the simple wizards in Mach 3 to do crude milling.
    Can you recommend CAD/CAM software to make very simple objects. I'm looking for something easy to learn and use but something that is well supported and documented and has a strong following so that there will be good forum help.
    With any such software, I'll need to invest the time to learn it and become profficient, so I want to make sure I'm investing in the right software. So I'm looking for strong recommendations.
    Thanks, :cheers:
    Mar 2003
    35538
    If you don't want to spend any money, try using ProgeCAD http://www.cnczone.com/forums/showthread.php?t=33589
    and LazyCAM in Mach3. Or try the SheetCAM demo. The SheetCAM author Les will give you an extended demo license if you want more time to play with it. SheetCAM has a very good user group on Yahoo, and Les also answers questions here fairly quickly to.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2006
    65
    I don't mind shelling out a few bucks, I just want something that will be around a while and its worth the effort investment. At the same time its got to be simple. I really dont want to become an expert, I just want to crank out a simple part every so often, so it should be intuitive. By Simple parts, I mean I make simple automotive brackets and adapters, your classic simple geometries.
    Jun 2003
    2103
    Check out Rhino and Madcam. They work together and are awesome.
    Mike
    No greater love can a man have than this, that he give his life for a friend.
    http://gcam.js.cx/index.php/Main_Page
    http://www.polaris.com.gr/gsimple/home.html
    these are both freeware and quite simple to use
    gcam you will need to add a dummy line for a lead in ,other than that simple software for straight forward parts
    Jan 2004
    3154
    You cna use Alibre free version for design and MecSoft has a starter CAM called FreeMill
    www.integratedmechanical.ca
    Mar 2007
    I am currently looking at Tebis and Nx4, why is tebis so expensive when nx can do the same, is there a advantage with tebis? can anyone comment, Thanks.
    Jan 2007
    10
    Cool Nx4 Can't Do What Tebis Can Do -not Yet
    LIGHT YEARS AWAY (chair) (chair)
    Price
    Cannot believe you think that all cad cam is the same, do you also believe that all cars are the same, all brands of tyres are just black rubber and the tooth fairy. It comes down to the useability, reliablty, ease of use and payback time.
    To fully investigate every solution would take far too much time. For you to try and evaluate a product yourself is also not feasable, you will spend too long evaluating the GUI, and not the cutting software, then you will forget about the features of the first one.
    Get a selection to come in and demo to you, also get them to give you code to run on your machine "Live".
    :wee:
    Quote Originally Posted by Tony the Ferret View Post
    To fully investigate every solution would take far too much time. For you to try and evaluate a product yourself is also not feasable,:wee:
    i don t think anyone here suggested all cad/cam is the same ,are we in the same forum same thread same page ?
    evaluate a product yourself is not feasable ?? how do you figure that ?
    if a guy is going to make a bracket or two a month ,how economical is it to spend any kind of serious money on something that can be so easily hand coded ,there are a lot of good gui softwares out there ,if a guy has the initiative to find them and try them
  1. Need spincasting (or other) recommendation
    By Oldsman68 in forum Casting Metals
    Last Post: 09-12-2007, 11:59 PM
  2. Need recommendation for a control box.
    By alexccmeister in forum Stepper Motors / Drives
    Last Post: 02-21-2007, 04:16 PM
  3. Recommendation Please
    By SPEEDRE in forum Autodesk
    Last Post: 02-13-2007, 12:33 AM
  4. mill recommendation
    By rickyt in forum Milltronics
    Last Post: 05-08-2006, 05:07 PM
  5. lathe recommendation
    By marty7001 in forum Uncategorised MetalWorking Machines
    Last Post: 04-28-2006, 05:43 AM
