587,193 active members*
2,520 visitors online*
    Jan 2007
    CAD CAM recommendation
    Hi all.I am at present routing fairly simple parts on my machine.I do not have a vacuum table and am holding the plywood sheets down with double sided tape.This is very messy and not reliable.what I need is a cad cam package that will allow me to leave tabs in predetermined places to hold the part in the sheet.Any Ideas on a package. Machine is a Denford Triac running VR milling 5.2 and Quickcam 2d.
    Many thanks
    Mar 2003
    35538
    Check out Vectrics products. www.vectric.com
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Cam Recommendation
    By dgoddard in forum Uncategorised CAM Discussion
    Last Post: 06-15-2007, 02:38 PM
  2. CAD/CAM recommendation
    By split63 in forum Uncategorised CAM Discussion
    Last Post: 06-11-2007, 11:59 PM
  3. Need recommendation for a control box.
    By alexccmeister in forum Stepper Motors / Drives
    Last Post: 02-21-2007, 04:16 PM
  4. Recommendation Please
    By SPEEDRE in forum Autodesk
    Last Post: 02-13-2007, 12:33 AM
  5. Paint Recommendation
    By ChrisJ in forum Vertical Mill, Lathe Project Log
    Last Post: 10-06-2005, 08:30 AM
