603,795 active members*
3,048 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > CAD drawings of most popular V8 engine bellhousing patterns
Page 5 of 5 345
Results 81 to 90 of 90
  1. #81
    Apr 2005
    460
    Re: CAD drawings of most popular V8 engine bellhousing patterns
    I think its same as 460 ford just different size dowel pins
  2. #82
    Apr 2005
    460
    Re: Need 518/46 RH bolt pattern
    Could you put the back half of a 518 on a 727?
  3. #83
    Apr 2023
    Smile Mopar 440 Bellhousing Dimensions
    For anyone looking for some Mopar 440 RB B/B Bellhousing dimensions, have a look at the attached PDF.
  4. #84
    Tossing this out there in hopes...I'm trying to adapt an A833 Dodge transmission to a 1946 Dodge truck bellhousing. I've got most of the proper information, however I don't have a dimension for the location of the bellhousing bolt locations to the center hole. I have their spacing in relation to each other, and I have the A833 side, I just need to locate the four bolt pattern on the bell housing to it's center hole. I can't get accurate enough information with the bellhousing in the truck. Does anyone have a drawing?
Page 5 of 5 345
  1. Popular presents.......
    By MarkusD in forum Portfolio Board
    Last Post: 02-13-2014, 01:29 PM
  2. What will I make Is the popular question...
    By milhead in forum CNC Wood Router Project Log
    Last Post: 02-08-2012, 12:40 AM
  3. Big Block Chev Bellhousing Dimensions
    By hellcycledoctor in forum Australia, New Zealand Club House
    Last Post: 03-30-2010, 11:27 PM
  4. drawing board drawings to cad drawings
    By mike hide in forum Uncategorised CAM Discussion
    Last Post: 03-23-2009, 10:35 AM
  5. single cylinder engine drawings?
    By savvypower in forum MetalWork Discussion
    Last Post: 02-01-2007, 12:44 PM
