587,999 active members*
2,262 visitors online*
Results 1 to 4 of 4
    Jan 2004
    490
    Calcomp 1041 plotter
    I have the oportunity to buy a Calcomp 1041 for $75. First, assuming it works, would I be able to print T-shirts or bumper stickers? Assuming it doesn't work, would there be any good motor or controller assemblies on it? Does anybody know anything about these things? I have a few ideas for those two projects, that I thought of taking to auto swap meets, and shows, but would like to know if it s worth it. The only thing I was able to check out at all, is the slide assembly, and I don't find a lot of use out of that for other projects. Somebody, anybody...please!
    Cheers,
    Jens
    Stop talking about it and do it already!!!!!
    Jan 2005
    746
    jens,
    I would first find out if you can still get pens/markers for it, if not then it is not worth it. The markers would have to be the permanent type. I don't know how you would get t-shirts to move back and forth on the roller without bunching up.
    If it is anything like the 1012 that I had scraped out, all I saved was one large power supply and two small Pittman servo motors. The motors were not even big enough for a cnc router table, I will probably use them in one of my model boats. Fifteen years ago I think I paid about $60 for the plotter and never used it, my intentions were good but never materialized.
    If it's not nailed down, it's mine.
    If I can pry it loose, it's not nailed down.
    Jan 2004
    490
    Thanks for the tip. I think I may scroung up the funds anyway, and flip it on ebay...like you said, if consumables are still available.
    Jan 2005
    746
    hobbiest,
    I was just going thru the McMaster-Carr on-line catalog and found that they have plotter pens for the 104X series plotters. I think they were $9.96 each and had black and a few other colors.
  1. HP 7475A Plotter Help
    By VNSPEC22 in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 08-22-2010, 03:10 PM
  2. XP driver for HP plotter
    By Fixxit in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 09-05-2007, 07:56 AM
  3. 1012 plotter
    By 2muchstuff in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 02-26-2005, 05:39 AM
  4. HP 7475 plotter
    By Stevie in forum CNC Machine Related Electronics
    Last Post: 03-20-2004, 04:43 PM
