588,506 active members*
6,000 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > calculating expected max cutting force required
Results 1 to 10 of 10
    Apr 2006
    1016
    where to begin?
    Looking to design a r/p table with 3.6 gear ratio for 4x8 table with dual
    y motors. With x and y using NEMA 34 HIGH TORQUE STEPPER MOTOR 1160 oz-in
    Mar 2003
    35538
    What are you cutting, and what are you using for a spindle, and how fast do you want to cut?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2006
    1016
    going to be cut oak 3/4 raised panel doors, some light alunmin
    machining for future parts for cnc add ons, some mdf for doors,
    want to do verneer inlays for table tops floors etc. see pic of inlay
    below..... want this boy to have speed...
    just say dont want to be there all day cutting one part
    lets say, for now a cnc router ... if all goes well i will design or buy a diy spindle, or buy a resonable low cost one.. not sure where they price out if u bought off shelf? any one phase units out there?
    Mar 2003
    35538
    spindle?
    Gerry
    Mar 2003
    35538
    If you use a handheld router for the spindle, figure 30-50lbs or so. If you use a real spindle (5HP), you can figure closer to 100lbs or so, maybe 150. That should get you in the ballpark
    Gerry
    Apr 2006
    1016
    so if you did diy spindle from 3-5 hp ac motor gear her down 8000 rmp
    I still would need 100 lbs.. how to cal that respect to motors ...should i go servo on x, y on a large table 4x8 what my pro and cons
    Jul 2005
    12177
    Quote Originally Posted by eloid View Post
    where to begin?....
    It might sound a bit funny but this it not what you need to worry about. In one of your posts you say; ..... want this boy to have speed... and speed is pointless without acceleration. You need to size your drives to obtain the acceleration and speed you want; the acceleration load is much greater than any cutting load.
    Apr 2006
    1016
    Quote Originally Posted by Geof View Post
    the speed comment was refering to time it takes to complete a cnc job
    from beging to end..... in hours
    so where do I start... in figuring out my accelation speed / load
    evering thing is in a design mode still.. open to suggestion...
    machine will be a rack and pinion desgn.. 2 y motors.... with timing shaft to
    pinion / motor table size larger enought to cut a 4x8...
    x is a ball screw for now. 5/8x .2 x motor same size and torque as Y axis
    ( have not order them) z drive ballscrew 5/8x .2 motor 480nm
    y axis will be some kind of linear rail
    Jun 2005
    194
    Force & Power
    Perhaps this will help.
    Good Luck,
    Attached Files Attached Files
    JR Walcott
    Georgia Machine Tool Resources, LLC
    Sep 2007
    740
  1. Typical cutting force
    By Evilness in forum DIY CNC Router Table Machines
    Last Post: 01-17-2023, 03:14 AM
  2. Plasma cutting Help required
    By 01_nasty in forum Waterjet General Topics
    Last Post: 10-14-2007, 09:26 PM
  3. Cutting / Thust Force
    By juanca in forum Mechanical Calculations/Engineering Design
    Last Post: 09-15-2006, 02:00 AM
  4. cutting force calcs
    By Tris in forum Material Machining Solutions
    Last Post: 11-27-2005, 12:16 PM
  5. Calculating draw bar force on R8 collet
    By h3ndrix in forum Uncategorised MetalWorking Machines
    Last Post: 07-27-2005, 10:51 PM
