587,235 active members*
3,450 visitors online*
IndustryArena Forum > Mechanical Engineering > Mechanical Calculations/Engineering Design > Calculating vessel pressure from material tensile strength
    Jan 2008
    47
    I'm pretending to be an engineer to design a product. Since I'm not actually a degree-holding, legit engineer, I need the help of someone who is!
    What I'm trying to do is to select a suitable material to construct a cylindrical pressure vessel. You wouldn't use paper (in single sheet thickness) to make an air-compressor tank because the material's tensile strength is too low to contain the typical 150psi that must be stored, right? I want to know the formula for calculating this. Do not worry about the mechanics of the ends of the cylinder; I am only concerned with the outward forces exerted on the cylinder walls.
    The information I have (and units I'm using):
    -Tensile strength of various materials (psi)
    -The thickness of the material (inch)
    -The diameter of the tank to be constructed. (inch)
    -The amount of pressure that must be held (psi)
    Although the tensile strength and containable pressure are both measured in psi, I know there is some math involved that takes the cross-sectional shape and size of the containing vessel (in this case, circular) into account. Otherwise, a tank made from carbon-fiber could hold up to 175,000 psi at any size diameter and I know this is not the case. Its probably some stupidly simple formula that a mechanical engineer would think was common knowledge.
    Thanks for your feedback.
    Feb 2006
    210
    Re: Calculating vessel pressure from material tensile strength
    Basically you take the cross section area of the vessel, say 100 sq inches. Multiply this times the psi. 100 x 150 = 15000 lbs. then you take the area of the shell material and multiply it by the material tensile strength. This better be greater than the first number. For safety 3 to 5 times greater.
    In the words of the Toolman--If you didn't make it yourself, it's not really yours!
    Remember- done beats perfect every time!!
    Jan 2008
    47
    Excellent! Thank you.
    In equation form:
    Ax= cross-sectional area in sq.in.
    P= pressure to hold in psi
    As= surface area of vessel in sq.in
    T= tensile strength of vessel material in psi
    Ax x P x 3 < As x T
    The 3 is the minimum safety factor
  1. Shear strength, yield strength
    By AirChunk in forum Mechanical Calculations/Engineering Design
    Last Post: 09-16-2010, 08:34 PM
  2. Tensile Specimens
    By IITStaff in forum Employment Opportunity
    Last Post: 09-09-2009, 10:59 PM
  3. Material strength
    By Karlf in forum Composites, Exotic Metals etc
    Last Post: 07-24-2008, 03:17 AM
  4. tensile strength
    By pp-TG in forum Mechanical Calculations/Engineering Design
    Last Post: 11-30-2006, 02:14 PM
  5. Torsional strength of material
    By zoeper in forum Mechanical Calculations/Engineering Design
    Last Post: 08-11-2006, 12:17 PM
