Hi all,
I have a Flow 5 Axis Waterjet with a Simens Numerik 840d controller. When I calibrate the machine in the B and C Axis to a dial indicator to figure out the deviance in which those axis' are out, how do I put that offset into this controller? For example, if the B Axis calibration is out 10 degrees, where do I enter that 10 degrees so that the controller will compensate for that so that the B Axis is truly at 0 degrees? Thanks for any help in advance.
