603,804 active members*
3,632 visitors online*
    Nov 2006
    8
    Question Calibrating NEOLT MX2000
    Hello,
    I would like to know if someone know how to calibrate a NEOLT MX2000 using StoneCAD. Version 2.1 or 3.1
    Gustavo.
    Nov 2006
    8
    Usually problems on precission for NEOLT MXDigit 2000 are caused by not cleaned or defected metallic band for movement reading.
    Other possible cause, may be some wiring assembly disconnected, or some trimmer to adjust, this last calibration needs of an oscilloscope and it is a technical procedure made by instructed technicians.
    If all this pars are ok, can be some problems on CPU board (this part is the faster item to check)
