603,383 active members*
3,607 visitors online*
    May 2004
    600
    Calling all stamping experts
    Hi everyone, I'm going to be producing some metal cabinets measuring 1500mm wide x 660 deep x 1340 high (59" x 36" x 53") but I need to put 2 lateral reinforcements along the 1500 side, one at 1/3 height and one at 2/3 height. I'm using 2.0mm (12 guage) sheet metal. The quantities for the product are likely to be reasonable and also long term so I was wondering about the possibility of stamping a strengthening line as per my AutoCAD drawing below. Even though the shape to be stamped is simple, I do realise the tooling gets expensive on something this long (probably 1400mm long stamp line) but I'm going to look at it. I am ignorant of stamping procedures and if viable, I would contract out the stamping part. I do however have some questions if there is anyone with experience in this field.
    In this case I'd imagine there would be a male and female die/form with the shape machined into it in male and female versions. The press comes down and stamps the shape into the metal. This part is simple but what I don't know is if this requires a 2 stage die (if that's the correct name) where stage one comes down and clamps the surrounding material with high tonnage then stage two comes down and stamps the line. I'd imagine with a simple one stage press tool which only stamps the line, the surrounding area would crease. Is this the case? If so, I'd imagine my idea of stamping this looses it viability. If this isn't the right forum to ask about this does anyone know of another forum where I could get advice from?
    Thanks in advance.
    skippy
    Attached Files Attached Files
    Nov 2006
    925
    Put your drawing in a format that can be seen easily.
    May 2004
    600
    wish I could but dwg and dxf are all I've got. Sorry.
  1. swipe stamping?
    By Med-Pac in forum Diemaking / Diecutting
    Last Post: 01-25-2009, 08:34 PM
  2. Stamping?
    By dal in forum Casting Metals
    Last Post: 09-21-2008, 06:22 AM
  3. Time Stamping CNC Programs
    By kballance in forum Fanuc
    Last Post: 05-27-2008, 09:30 PM
  4. Calling on experts to help spread your knowledge
    By Swiss in forum Community Club House
    Last Post: 07-28-2007, 12:58 AM
  5. stamping
    By MBG in forum Bending, Forging, Extrusion...
    Last Post: 10-19-2005, 01:48 PM
