I'm sure the forum gets this request a lot. I'm shopping for a CAM package to run my 3+2 head/table machine that I am nearly through building. Please see drawing here (the same as what I hope appears on this post below): http://www.airgunstocks.com/images/m...axis_notes.jpg Note when R2 rotates, the entire Y and Z assembly rotate.
I have been looking at CAM packages for a long time and still unsure what might be the best value and be able to work with my machine. As a startup I want to keep the spending down until I make some money, but at the same time I want to ensure success so I can make money. I fear my machine has a unique situation that when R2 rotates, the cutter position translates in X and Z, so X and Z need to know to move when R2 rotates.
I'll be creating the artwork in Solidworks. It might be handy to be able to work tool paths from within Solidworks, but I don't want Solidworks to be tied up running the machine, so the CAM and controller software ideally need to operate the machine separate from SW. Which maybe means a CAM solution that does not run within SW at all.
thank you,
Michael
