587,625 active members*
3,203 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Cam software for reproducible sheet production
Hybrid View
    Jan 2018
    22
    I am looking for a cam program that will easily work in my business of producing aluminum sheet goods on a cnc router.
    Let me give some details on the current situation- I currently have Vectric Cut2d Pro and have built a Kronos 50x62 cnc router. In my business I cut approximately 25 different sizes of aluminum sheet goods. Most of the sheets are square or rectangular with rounded corners. The sizes are all pretty much the same with a custom size thrown in every once in a while. When I need to cut several sizes I take a template file that was created in Cut2d that has the various sizes on different layers. So, I enable the layer that has the specific size needed and then copy and paste that size depending upon how many are needed for the job. I then repeat that process for other sizes required. All sheets are cut from a master sheet that is 49x63
    I would like to have a cam program that I can choose the sheet size and quantity and then it nest it for cutting. The sheets can be of various sizes and quantities.
    If this is possible with Cut2d I would like to know how but if I require a different CAM program, I just need to be pointed in the right direction.
    Thanks!
    Ben Gasser
    Kansas City
    Apr 2005
    305
    Cool Re: Cam software for reproducible sheet production
    As you have a Pro version, there is a Nesting function.
    Check it out.
    https://www.vectric.com/products/cut....html#tnesting
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Mar 2003
    35538
    Paul Rowntree's CSV gadget may work, by allowing you to define your shapes in excel, then import into Cut2D Pro.
    Gadgets - Paul Rowntree
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Low cost sheet bend software
    By R.DesJardin in forum Bending, Forging, Extrusion...
    Last Post: 12-06-2010, 11:17 PM
  2. LaserQuote - Software for quoting and production control
    By laserquote in forum Waterjet General Topics
    Last Post: 11-26-2010, 10:20 AM
  3. Easy Development Sheet Metal software
    By Khalid in forum Bending, Forging, Extrusion...
    Last Post: 02-23-2008, 09:43 AM
