Hi there!
I've been having a go at knocking together an application for CAD/CAM generation.
It's still in the very early BETA stages at the moment, but so far it can
. Read/Write DXF files (still lots to do, but seems to cope with most 2D
files that I've thrown at it).
. View Gcode files
. 3D-ish viewing of drawing/gcode files.
. Scriptable via javascript and Visual Basic
. TTF text glyph extraction/engraving
. Bitmap heightmaps
. Very rudimentary gcode generation
It is a .NET windows application which requires at least framework
version 1.1.
The latest version and some pitiful but hopefully improving documentation can
be found at...
http://www.brusselsprout.org/CAMBAM
If you care to have a look at it and pass back any comments I would
be immeasurably grateful. It's still early days, so now would be
a good time for any feature/change requests as the design is
still rather fluid.
Once again, it is very much work in progress so expect it to be rough
around the edges
The main task ahead of me is to concentrate more on the gcode
generation side of it as I'm starting to use now for some
current projects.
I'll probably open-source it eventually, but the code is a bit
too ugly to be seen in public at the moment
Many thanks for your time
Thank you very much for the early beta testers who have had a sneaky
peaky at it.
Regards
Andy
