588,542 active members*
4,831 visitors online*
Thread: Camworks
    Feb 2013
    Question Camworks
    I need help on how to copy toolpaths from one file to program another part that is simular with slight geomitry changes in order to save time.
    Thanks in advance for any help
    Charles
    Mar 2008
    111
    under the camworks tab you can export the tool path save it somewhere you can find it. Open part 2 select import under the camorks tab and select the file you just saved. As long as the part is drawn in the same orintaion as part 1 is should be pretty close. it will also bring in tools to your tool crib from part 1
  1. Camworks
    By big_mak in forum CamWorks
    Last Post: 02-13-2017, 04:19 PM
  2. CAMWORKS
    By Arty3000 in forum CamWorks
    Last Post: 07-17-2014, 03:13 PM
  3. camworks
    By rc-intx1981 in forum CamWorks
    Last Post: 04-06-2012, 07:09 AM
  4. Camworks
    Last Post: 08-16-2011, 10:08 PM
  5. Camworks 3D
    By bobborck in forum CamWorks
    Last Post: 07-11-2008, 07:20 PM
