588,567 active members*
4,683 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Can I get some thoughts and idea's for counterweights for an X3?
    Mar 2009
    296
    I'm thinking maybe I should make a counterweight to help lift the head of my X3 because it is easy to make it go down but takes effort to go up. Thought it would be good to do before cncing it. I was thinking attach a pulley or 2 to the ceiling with a cable or 2 to the head with counterweights at the other end but what shall I attach the cables to on an X3 head? At first I was thinking about 2 of the 4 allen bolts where the head bolts on but you can't do that on the left side because that box with the emergency shutoff switch is in the way. Do I mutilate the head and maybe ruin the warranty by drilling and tapping a bolt hole or 2? Seems like my only good option.
    Apr 2003
    354
    Here's a link to how I made mine. http://www.cnczone.com/forums/showthread.php?t=72921
    I drilled & tapped a hole. Dunno if that affects the warranty; never had any problems (knock on wood).
    Mar 2009
    296
    Thanks Dickeybird!
  1. Think im going to get a X4... any thoughts?
    By simila95 in forum Benchtop Machines
    Last Post: 04-16-2009, 04:16 PM
  2. ANY IDEA'S: FADAL PROBLEM
    By raps in forum Fadal
    Last Post: 11-25-2007, 05:11 PM
  3. CNC thoughts
    By Tekko in forum Benchtop Machines
    Last Post: 02-12-2007, 02:20 PM
  4. First thoughts for new design
    By Pairair in forum DIY CNC Router Table Machines
    Last Post: 09-10-2005, 04:19 PM
  5. BC.....Other thoughts
    By dk1machine in forum BobCad-Cam
    Last Post: 07-06-2004, 12:12 PM
