Hello,
I have the X and Y axis working, but not the Z. In the past I have used a 2.5 axis Bridgeport EZ Track mill that would pause when it saw a change is Z. You would provide the Z change and the press the cycle start to resume the program.
The other place this was nice was in drilling cycles. The machine moved in the X and Y and you pressed the cycle start after you drilled each hole and raised the quill.
Is there any way to make Mach do this?
Thanks,
Mike
