On my diy 3 axes router I used ¾ steel rod for the x axes, way too small. When the y axes is above 25 ipm the gentry starts to shake. I have had the x axes up to 40 ipm with no problems, but I can’t add a load or keep it at that speed long enough to determine if Turbo CNC can make the adjustments between 25 ipm on the y and 40 ipm on the x. My question is can I run the x and z axes at 40 ipm and the y at 25 ipm, will Turbo CNC allow the router to go faster on the x axes and slow it down for the y axes? I am running Desk Proto for my cam and it won’t allow me to adjust ipm for each axes. In order for me to run at a higher ipm on the x and z axes I will need to get new lead screws with a lower tpi and/or get larger steppers, but I don’t want to put in the extra time and cost if my y axes causes the whole machine to run at a slower speed.
