Hi all,
I was just wondering if I can use the J8 Connector on the Xylotex board to run a set of limit switches, or should I just Y adapter the 5+ Volts coming from the board for the Home Switches? Can I use the J8 Connector on the Older 3 axis board for that, does that count as system logic, for limit switches?
Also, to run two fans on this board, where can I get the power for the second fan?
Thank you very much for your time.
I Really appreciate it.
