586,036 active members*
3,717 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Can my 3018, without alteration, do these wood and brass tasks...plus bit advice!
    Oct 2019
    4
    Well this grew in the telling! I initially wanted a cheap laser engraver to burn onto wood for hobby purposes. Somehow I ended up with a cheap 3018 Pro CNC machine with a 775 spindle motor that has more obvious capabilities than just the laser attachment.
    I fancy playing around making small wooden game boards for my kids. I'm thinking of hardwood (maple) boards with holes in them (for pegs, like cribbage) and possibly larger shallow disc type cut outs. Being new to woodwork and CNC I figure I need specific advice on what sort of bits will do what I want that will fit the ER11 collet. The machine was only supplied with 10 x 'drill bits' that I believe are the standard fluted carving bits.
    Questions:
    1. Peg holes: For drilling peg type holes, will the standard bits work or should I get a proper drill bit as I would a proper drill bit if I were doing this with an electric hand drill?
    2. Shallow disc shapes: I believe that with the bigger disc size cut-outs e.g 30mm wide x 3mm deep circles, that the supplied bits could carve out the cut-outs but is there a more efficient attachment/bit that will do this?
    3. Brass: Slightly leftfield, I saw a 3018 machine milling brass (slowly!) on a YouTube video. Could it, in theory, mill out a brass branding stamp, like the kind you use to burn into wood or stamp leather e.g: https://brandingirons.com/products/c...branding-heads. If so, what sort of bit might be used?
    4. Software. Easel, seems relatively easy to use and with its free hobby use at four projects a month, seems like it might be a good fit for what I want i.e. few simple designs using shapes as described above. However, I am a fan of software that is run on my own PC rather than browser based direct-from-a-website. Is there an equivalent that is free or relatively cheap that can be run from a PC?
    Dan
    Jul 2020
    Re: Can my 3018, without alteration, do these wood and brass tasks...plus bit advice!
    very interesting. do you read additional literature or information?
    I can advise https://baseb.io/content/blog/morale...p-to-scale-up/, here you will also find useful information
  1. Different bits for different tasks?
    By htraps in forum Chinese Machines
    Last Post: 04-09-2019, 10:09 AM
  2. Making Iron Heat Stamp on Brass - V Carving on brass with 20 degree V-Bit
    By kostas1 in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 03-02-2018, 05:00 PM
  3. Replies: 10
    Last Post: 01-16-2013, 06:52 AM
  4. Advice needed for spindle, milling brass
    By autophile in forum Commercial CNC Wood Routers
    Last Post: 09-16-2009, 06:43 PM
  5. Alteration Shape for Bearings
    By SPEEDRE in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 07-24-2007, 12:09 AM
