Hi all,
Thank you so much when reading my problems and help me.
I have Geminis CNC 5-870/3000 with controller Fanuc 0TC get problems as below:
The BAT was lost, I reentered CNC parameter and PMC Parameter following the my list data. After that, the X,Z axis can move normally, the tool index can rotate by manual. But when I call the tool by T address (Auto or MDI Mode), the massage No.2014: "Make Reference Search"
I suspect that I must set the Zero position for the Turret, but unlucky, I did not have any document to follow.
I thanks for any help to troubleshooting this problem.
Thanks and Best Regards
Natech
