603,935 active members*
4,434 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > can okuma run by autodesk software hsm or future cam?
    Jun 2017
    13
    many many thanks to this forum members in advance ,big explanation i need about okuma control ,does okuma machine run by autodesk products hsm or future cam ,what is the difference between other cam manufacturer on okuma vmc machine? your answer is highly helpful from this side of the world
    Apr 2009
    1273
    Re: can okuma run by autodesk software hsm or future cam?
    Okuma uses straight G-code programming which basically all cam systems support. Pick what CAD/CAM you like and what is best suited to your needs and download the G-code to the machine. Then carefully prove out your code with single block on, feedrate down, and "distance to go" displayed. In theory simple, in reality, DOE....
    Best regards,
    Experience is what you get just after you needed it.
  1. Best software for future employment
    By jm82792 in forum Uncategorised CAM Discussion
    Last Post: 06-28-2017, 01:50 AM
  2. Autodesk and Topcon Show Future of Construction at ConExpo 2014
    By cncadmin in forum News Announcements
    Last Post: 03-05-2014, 11:20 PM
  3. Software errors, future extensions and drives not ready.
    By chuckie34 in forum SIEMENS -> GENERAL
    Last Post: 01-07-2014, 12:34 AM
  4. Autodesk CEO Carl Bass Thinks The Future Of Hardware Startups Extends To The Moon And
    By cncadmin in forum 3D Printer / 3D Scanner Discussion
    Last Post: 10-19-2013, 01:30 AM
  5. The Future of CAD/CAM Software
    By kackermann in forum News Announcements
    Last Post: 02-20-2011, 10:18 PM
