587,997 active members*
1,658 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Can a scanned pencil drawing be used?
Results 1 to 14 of 14
    Jan 2007
    68
    Question Can a scanned pencil drawing be used?
    I would like to scan a pencil drawing into a 2D CAD program. Can this be done? I'm brand new to CAD and I would like to start off using my drawing if possible.
    I have not purchased any software yet and I'm considering the Romaxx desktop CNC Router for prototyping and hobby use.
    Thanks, :drowning:
    Bill J.
    Knoxville, TN
    Jan 2007
    634
    Yes it is very possible. Many programs can take an image straight to a model or a g-code. It is much, much easier if you import the scan into a photo program like Adobe or Corel and drop it to 1-bit mode (B&W only, no shading) first. It is just way easier to clean up first in a program meant for it than trying to mess with the chaos of a raw scan straight to CAM software. Otherwise you will get the darker pencil streaks deeper than the lighter ones - everything will be a wildly textured and uneven gradient if you don't do that first with scans, especially pencil.)
    This is of course assuming you are not going for a true 3D artistic textured look, but a more of a standard 2.5D path. As an aside, if you ever get bored and want to try something new, pencil sketches reduced to 4-bit or 8-bit images can make some neat intaglio-style hand-engraved looking output if you play around with it and cut with a very narrow, small included angle bit.
    I help my friend cheat and cut his woodblocks using photoshop and this trick.
    May 2003
    96
    HI Stepper, can you be a bit more elaborate about the process with photoshop as I have tried in the past but unsuccessful.
    regards
    Martin G
    Aug 2005
    51
    You might try using inkscape to turn your scan to a vector
    format. Its free and quite nice.
    John
    Jan 2007
    68
    I'll give it a try and Thanks
    Thanks Stepper Monkey,
    I have used Adobe Photoshop 5 a good bit and will try this right now. Just to give you an idea of my understanding, I would have been lost if you didn’t explain black and white vs. gray scale because I did not understand the term 1 bit. I can only assume at this point that Adobe has the ability to convert the file extension to one that a CAD program can use. ??? I’ll try this out.
    Thanks John, I will look into this software.
    You guys are really helping a new guy build confidence.
    Thank You,:cheers:
    Bill J.
    May 2004
    314
    bjenkins,
    download and try the free trial of bobcad, it comes with a trial of bobart pro
    ive had good results with it and its quite cheap especially if you buy before they start with the new v22 and/or. another way to go thats free forever is a free program called wintopo. there are two versions a free forever one and a pro version with a demo with some sort of limits. Depending on what you are actually are going to do, watch for a programs ability to generate a centerline of your scanned art lines. for example your art is a 1/16 wide black marker line. some programs will only define the outside of that shape. so what would be on the screen is a hollow outline drawn around that black line.
    thats fine for some things, but some uses need for a single centerline to be created in order to machine fine text or even simply to represent a line drawing with actual lines. play around, there are lots of free demos and freeware out there thats jsut as good as expensive stuff. if youd like, post a scanned drawing here in bmp and id be more that happy to see whats possible with bobart. Im sure others would offer the same. Im going to send you a link to a thread that i cant find at the moment, check your message box.
    Ed
    E3 Foam
    Lemon Curry??
    Jan 2007
    68
    Progress see below
    See next thread
    Jan 2007
    68
    Progress see below
    See next thread
    Jan 2007
    68
    I used BobArt to convert my drawing from a BMP to CAD
    Thanks for the information. By learning that it is possible to convert a scanned drawing, I was able to use BobArt which is an add on for BobCad/CAM.
    Open BobCad and select Open BobArt in the File tab. Then select Load Bitmap Picture in the BobArt File tab. Then select the 2D tab and select Vectorize, check OK and finally, select Send 2D Contours to CAD Window in the file tab. After that you can save the image in BobCad using the Save As option in the File tab in BobCad.
    As mentioned by those that offered help, it is possible to convert scanned drawings and there are other ways of doing this. Now I will start learning how to work with my drawing in CAD.
    Bill J.
    Jan 2007
    68
    Thank You
    Thanks to all that contributed to this thread. I think by starting with a scanned paper drawing I will learn CAD a lot quicker.
    Bill J. :idea:
    Feb 2007
    33
    if you did not buy a program yt let me know i know the perfect program for you.
    Dec 2003
    24220
    If you have Corel Draw, this may help.
    http://www.torchmate.com/assistance/convert.htm
    Al.
    Albert E.
    Sep 2004
    218
    I have used sketched drawings and hand drawn concept ideas before by scanning the image and taking it into autocad. This way I have the rough conceptual sketch infront of me on the drawing board and I can then draw the lines out tracing the rough sketch image outline. After I get the concept of idea established in cad I delete the image and then I have a rough set of drawings to work from and rescale and dimension as needed.
    Its nots a way to direct scan image to dxf or g-code but its not a bad way to help you learn cad since your new to that as well. This only works on 2D working drawings of course since your scanned image will lay flat on the drawing plane. Although you can insert mutliple images and rotate them to the correct plane if you wanted.
    Bo
    Feb 2007
    26
    if you have a scanned a drawing and manage to get it saved as a jpeg. you could open up CAD and coopy and paste. works for me.
    Have a question. do i need bobcad/cam to run bobart to mill out wood. if so does anyone know where i might purchase a reasonably priced complete package. saw the tutorial seems like a smart piece of kit.
  1. Which CAD package for pencil and paper man
    By martinw in forum Uncategorised CAM Discussion
    Last Post: 01-11-2007, 01:14 AM
  2. Pencil grinders
    By J Solinger in forum DIY CNC Router Table Machines
    Last Post: 10-28-2006, 05:18 AM
  3. scanned art to DXF
    By fastolds in forum Uncategorised CAM Discussion
    Last Post: 06-23-2005, 06:09 AM
  4. Drawing ?
    By Ken_Shea in forum OneCNC
    Last Post: 06-09-2003, 04:54 AM
  5. modifying a drawing
    Last Post: 05-24-2003, 08:08 PM
