There are a bunch of ways to make "a part" with 3D tech such as SLS. We run several different types of rapid prototyping equipment here. Good stuff, and although the tech has come a LONG ways in a relatively short amount of time, it is still limited in it's utility, accuracy and certainly in it's cost factor. Where many of these technologies really make sense is in the design and proto stage, where it's quick to make one to test, rather than commit traditional resources to programming and manufacturing. For instance you might produce pieces of a housing on a RP machine. Test the fit of the circuit boards, display and buttons, maybe even use it as promo material or for a pitch to investors. When the times comes it's going to be hard to beat injection molding for low overall cost per part. You've got the investment in tooling, which is what you save in buying a rapid prototyping machine for design itterations.
