603,936 active members*
2,188 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Can you adjust the screen font size ?
Results 1 to 4 of 4
    Aug 2005
    4
    Hello,
    Does anyone know how (or if ) the font size on the screen can be enlarged to make it easier to read ? I have the CNC 88 control.
    Apr 2008
    6
    We recently had an issue with the X axis display being just out of sight on the screen. I was able to adjust with variable pots, on the right hand side of the box behind the screen. This would make the display appear larger or smaller depending on which you turned, and how much. I would like to caution you that soon after this we had the entire screen replaced.
    Aug 2007
    95
    Shift + the equal sign while the program is running will give you a large font
    Mar 2003
    900
    The shift + will only enlarge the axis position display. There is no way to change the font size of the program characters.
    Neal
  1. Homemade Screen Printer/Silk Screen
    By Sbthomas13 in forum Machine Created Art
    Last Post: 02-14-2009, 01:35 AM
  2. Changing screen size or a keyboard trigger for the reset button
    By maxboostbusa in forum Mach Software (ArtSoft software)
    Last Post: 03-16-2008, 07:54 PM
  3. How to size screen down
    By SupermotoAbuser in forum Mach Mill
    Last Post: 03-15-2007, 02:10 PM
  4. Screen size ?? What to expect?
    By murphy625 in forum CamSoft Products
    Last Post: 04-12-2005, 05:20 PM
