603,965 active members*
3,150 visitors online*
Results 1 to 4 of 4
    Apr 2012
    83
    Can you do a macro call (M) and pass a string somehow?
    I know you can use PQR variables or #variables, but is there a way to pass a string such as "HELLO" to a macro? Something similar to:
    M5001 "HELLO"
    or even
    M5001 ;"HELLO"
    if i could access this line in the script...
    Thanks,
    Alan
    Mar 2003
    35494
    What do you want to do with the string?
    I think you can have the M5001 open a dialog box for text input. Would that work?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2012
    83
    Hi Gerry,
    I want to send a command string of some sort. Right now I have a macro like this:
    'Multipass Rectangle
    '#2000=X1; #2001=Y1; #2002=X2; #2003=Y2; #2004=Z1; #2005=Z2; #2006=ZPassDepth
    '#2007=ToolAdjustment (0 none, 1 inside, or 2 outside)
    '#1002=ZClear; #1003=PlungeRate; #1004=FeedRate; #1005=ToolDiam;
    #2000=1 #2001=2 #2002=4 #2003=1 #2004=0.0 #2005=-0.5 #2006=0.1 #2007=0 M5002
    But it would be nicer to have something more like this:
    M5002 "rect,(1,2),(4,1),(0,-0.5,0.1),inside"
    Thanks,
    Alan
    Mar 2003
    35494
    Thanks,
    Can't do that with Mach3.
    Gerry
  1. G65 macro call
    By ggborgen in forum Fanuc
    Last Post: 09-29-2014, 10:25 PM
  2. 18T dowload to pc no eob just long string
    By karlbushnell in forum Fanuc
    Last Post: 01-28-2011, 02:55 PM
  3. Zap String
    By Aplus in forum Bridgeport / Hardinge Mills
    Last Post: 11-04-2009, 05:01 AM
  4. +Newbie, CNC string winder build
    By brownebasses in forum CNC Machine Related Electronics
    Last Post: 11-21-2008, 07:38 PM
  5. 3 phase with idler and draw string only
    By gtslabs in forum CNC Machine Related Electronics
    Last Post: 06-19-2004, 10:11 PM
