603,366 active members*
4,047 visitors online*
    Aug 2005
    Question Can you import an FGC file into a program to edit it?
    hello. I'm trying to find out if I can import an FGC file into a program so that I can edit it. Change the size add more cuts that sort of thing. Can anyone help me. I have a plasma cutter and using Flashcut CNC to run it, but no way of editing the designs that are already FGC files... any advice would be helpful. Thank you.
    Mar 2003
    45
    The .fgc file is a text file and you can use any text editor program to change it - like Window's Word Pad.
    You can also use the text editor built into the Flashcut software.
    If you wish to keep your original version intact, just use "Save As" and use a new file name for the modified file.
    plm
    Aug 2005
    Thank you I will try that!
