587,202 active members*
3,058 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Can you make G-Code With Corel
Results 1 to 7 of 7
    Aug 2004
    210
    Can you make G-Code With Corel Draw 12 ????
    May 2004
    350
    I dont think so. But you can make a dxf then convert it using another program
    Mar 2003
    35538
    Use ACE from http://www.dakeng.com, or better yet, SheetCAM. http://www.sheetcam.com
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2005
    15
    In Corel Draw you can save the file as a DXF and open the file in BobCad. You can use the contours for 2D paths. You can also create solids for these contours. If you use BobArt you can emboss these contours. This will also allow you to put shapes along these contours to form tool paths like what you would see on a coin face. Sign makers, Grave Stone makers, Furniture makers, Mold makers, or anyone needing to place logos, designs, or pictures on a surface. www.bobcad.com
    Apr 2005
    131
    Unhappy Dxf in bobart?
    Hi, I just got myself the bobCAD-CAM-ART package v19, there don't seem to be a way to import DXF in bobart. Not that I care but what would be the point in doing so? I'd love to understand. Thanks
    Para
    Sep 2005
    15
    Open a DXF file
    Open the DXF file in BobCad, then open BobArt. Select the lines or contours you need to emboss on the BobCad side. Then you can select the embossing parameters on the BobArt side. Hope this helps
    Aug 2005
    40
    biggermens , yes like the folks said...just export eps or save as dfx and one of your programs will convert it to gcode......what are you trying to do with it....All i use for design is Corel 11 and use Vcarve for all my sign work..gcode...
    Grizzmo
