586,069 active members*
3,323 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Can't control my spindle speed
Page 1 of 2 12
Results 1 to 20 of 21
    Sep 2005
    371
    LONG POST - Apologies
    (somewhat of a cross-post here...)
    Using Mach 3, Version R3.043.022
    Using xylotex XS-3525/8S-4
    Using cnc4pc C11 Rev 7.2 board
    Using Harbor Freight Mini-Mill (44991) with stock DC motor
    Over the holidays I got a hand-held tachometer and decided to check the spindle speed of my Mini-mill (HF-44991) against what it was showing in Mach3. Now mind you I had control in the ability to increase or decrease the rpm's before all this started.
    I noticed that the speed was off by a several hundred rpm and decided to tune it. So here we go. I tried the automatic spindle calibration within Mach3 R3.043.022, but decided to cancel before I got to far since it seemed to be taking way too long. I then began just typing in the speed and checking against the tach and created a table of corresponding spindle rpms vs tach rpms.
    I've restarted Mach3, I've saved settings, etc., but I can't seem to get the changes to take place.
    Not sure how the AutoCal works since I don't have any feedback to system regarding RPM. I did note that when selecting AutoCal the software does in fact cause the speed to increase gradually, but I always stop before it ends due to the latter reason.
    On the motor tuning of the spindle, I have:
    Steps per: 1000
    Velocity: 1500
    Accel: 161.25
    Step Pulse: 4
    Dir Pulse: 4
    Odd thing is, I can't change the Velocity. I can type in new numbers but when I click somewhere else on the dialog, the number reverts to 1500. (found out later it's because of the acceleration number, change that and you can change the velocity; posting here for someone else's benefit).
    On the Ports and Pins, Spindle Tab:
    Motor Control is set to Use Spindle Motor Output and Step/Dir. If I disable it, I can't get the spindle to turn at all.
    "ModBus Spindle - Use Step/Dir as well" is disabled
    "Special Functions - Use Spindle Feedback in Sync Mode" is disabled
    Since I didn't know where to go about making changes, I started with adjusting the pulley, but later found this is only a scaling for what's displayed in Mach.(posting here for someone else's benefit).
    THE ISSUE: I can't control the speed at all. I can see an increase in voltage from the C11 output as I increase the speed in Mach3, but now the motor only comes on at around 5V and runs max speed. Even increasing the voltage doesn't make an increase in actual motor rpm. In fact it starts the spindle motor to grunting like the brushes are about to come out.
    I reinstalled Mach3 and created a whole new config file from scratch, but it didn't resolve the issue, unless I still have my spindle motor tuning incorrect.
    I tested the rpm's with two other DC motors (tread mill type) and the issue is the same.
    I tested with another speed controller with both DC motors and again the issue is the same.
    All three motors were acting just like my mill motor in that they both made a grunting type sound due to the inconsistent voltage that is being applied. I had always thought it was the crappy brushes of the original mill motor, but now I know that it's related to the constant on/off voltage or something.
    I say something because both speed controllers are indicating 95v to 100v coming out of them going to the connected spindle motor. Once I get the output voltage of the C11 up to around 5V (by adjusting in Mach3, not the pot), the motor will come on. I still can't get any increase in rpm by increasing the spindle speed in Mach3. What's really odd is that when I continue to increase the speed in Mach3, that's when the slight decrease in RPM starts to occur and consequently the grunting starts.
    I believe I have adequately proved to myself that it isn't my motors and it isn't my speed controllers.
    Again, the only thing I changed on the C11 was rotating the potentiometer. I don't see any discoloration anywhere on the C11 board, chips or otherwise. I pushed on all the chips to check for tightness to be sure there weren’t any issues with them being loose.
    I now have the spindle tuning set to 1000 steps/per, the velocity maxed out (~6000) and the acceleration set to 6.25, and the spindle motor still runs wide open regardless of the spindle motor tuning settings.
    I've contacted Arturo and he's looked at the xml I sent him, but I said the xml looks fine. Hood, over in the Mach3 forum said the xml looked fine as well.
    That's why I'm posting here since I don't know whether it's Mach or the C11 board.
    Any help would be immensely appreciated! I would gladly call anyone willing to talk to me. Send me a PM with your phone number and I'd make the call.
    Thanks in advance,
    Vogavt
    Sep 2005
    371
    Okay, just an update. I totally uninstalled Mach via the control panel - Add Remove Programs, deleted my C:\Mach3 folder and started from scratch (other than my saved license and xml file).
    Still no joy....
    Anyone?
    Sep 2005
    371
    Has anyone used the C3 - INDEX PULSE BOARD with the C11?
    Arturo thinks this will resolve the issue. Not sure why I'd need to by an additional board when the C11 was working before all this started and the C11 already has a "built-in" Variable Speed Control.
    Anyone?
    Does the motor run correctly using the original manual pot?
    Might be a problem with the motor controller.
    Here's a troubleshooting guide.
    http://www.littlemachineshop.com/Ref...leshooting.pdf
    The c3 will input a pulse to mach to give real world rpm on the spindle screen.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Apr 2007
    2580
    Okay, I'll bite here.....
    Please understand that I am really not good with this stuff but I did however have the similar setup to yours. I have an CNC RF45 machine that uses a sensorless vector drive and it is running off the CNC4PC C11G board. I have full control of my spindle and while the speeds are not exactly what I type in they are very close. My machine has two tier pulleys on it so I do use the pulley setups in mach as that is what they are for. Basically from what I understand the spindle in mach is setup like another drive. The computer outputs a stream of pulses and the C11g Board converts the stream into a steady DC voltage that is then used to control a speed control device on a DC or 3ph AC motor like mine. It took me quite awhile of poking around to get mine to do what I wanted and it was not without frustration. I found that finding the steps per and velocity settings that output the max 10v and then working from there was the easiest way to get what I needed. I can crank up my machine to see what I have in there if it will help you but I doubt it will. It would seem to me that with just one pulley it would be simpler to say the least. I would just try to adjust the settings until you read 10vdc on the output at your desired max rpm. I fiddled with it trying to get the upper and lower settings to jibe but to be honest I never could get it spot on. It is probably within a hundred rpm or so and my max is in the 6k range now. I can spin it as slow as 140 rpm using the slower pulley setup. You might also borrow an Oscilloscope and see what the output looks like on it going to your motor. To check your machine and it;s controller, that is pretty simple, just temporarily put it back to stock and try it.....
    Again I do not completely understand how it works but there are a bunch of tutorial videos on the machsupport website about setting this up,they did help me to get it where it is now. Good luck and if there is anything I can check for you on my machine let me know.... peace
    If none of that works perhaps this will:
    [nomedia="http://www.youtube.com/watch?v=TsRenyiXh_A"]YouTube - mach3C6setup[/nomedia]
    Pete
    Sep 2005
    371
    Quote Originally Posted by hoss2006 View Post
    Might be a problem with the motor controller. Hoss
    Well I did test with another controller and had the same issue. I looked at the troubleshooting guide as well and tested the MOSFETs, but they all seemed to be okay.
    I can see an increase in voltage as I make changes to the rpm in Mach, but the DC motor won't turn until the voltage gets up to ~5v, then even increasing the voltage doesn't change the speed of the motor.
    Still stumped here.... maybe I can actually talk to Arturo tomorrow.
    Thanks for the suggestions!
    Sep 2005
    371
    After talking to Arturo (briefly), he suggested I look for lack of grounding of the spindle motor. So I started down the task of drawing out my wiring schematic and am posting it here for everyone's review.
    IMPORTANT LEGALESE NOTICE: This drawing is what works for my machine and as such I will not be responsible for your use if you choose to follow what works for me.
    Having said that, can someone provide some feedback as to what/where there might be an issue? With Arturo's grounding comment in mind, notice how I've got the machine/chassis/spindle motor grounded. I'm using the input to pin 11 as the ground which is also part of the touch probe. I'm not certain this is not adequate because I could control the spindle rpm before all this started. Just want someone else's opinion as well. I sent this drawing to Arturo yesterday but haven't heard back from him yet. Maybe today he and I can hook up.
    Thanks in advance,
    Vogavt
    Mar 2007
    2083
    Hi Vogavt ,
    it looks like the two wires connecting the C11 board to the MC 60 speed controller
    are crossed
    i'd expect P3 on the MC60 to be connected to the C11 ground
    and the P2 connect to the C11 0 to 10V
    disconnect the wires
    check the voltage between analogue GND and "0 to 10v" terminals on the C11 board
    changes as expected
    min speed = 0V , max speed + 10V WRT gnd terminal
    if not is the external power supply OK ?
    +12V at the 12V input WRT Analogue GND
    if you have the 5K0 potentiometer that originally set the speed
    connect it to test the MC 60 speed control
    P3 min speed end , P2 middle and P1 max speed end is about + 10V WRT P3
    treat this wiring as live
    on the FC250J board it is ( speed control on my lathe )
    P1 is connected to the positive terminal of the mains rectifier !!!
    if you don't have a potentiometer
    connecting P3 and P2 should give you zero volts to the motor terminals
    connecting P1 and P2 should be the maximum
    to make it easier to test on your bench
    use an ordinary 20W to 100W mains GLS bulb ( tungsten filament not fluoresent eco bulb)
    as a load instead of the motor
    John
    Sep 2005
    371
    Quote Originally Posted by john_100 View Post
    Hi Vogavt ,
    it looks like the two wires connecting the C11 board to the MC 60 speed controller are crossed
    John
    Switched the wires!
    :banana:
    @ john_100
    You're a genius! I looked at that, but you know sometimes 4 + 4 is 9 no matter what someone tells you (until it finally sinks in)
    I'll be revising the drawing shortly to reflect the switch. I looked at another drawing that I believe I got from Hoss's website and it showed the P2 and the P3 configured just like you said it needed to be. So I took a deep breath, switched the wires and voila! I can even make the spindle turn at 0.8Volts, at 9.9V I'm getting 4000 rpm.
    I did a belt drive upgrade. Different thread.
    Thanks for looking at it!
    Mar 2007
    2083
    Hi Vogavt ,
    I'm happy that I could help
    John
    Sep 2005
    371
    Updated Rev 5.
    For anyone wanting to look at it. I've cleaned it up a little as well since there may have been some confusion about the FC350BJ-110 board showing in the drawing (which is no longer used since it's blown).
    Attached Files Attached Files
    Aug 2016
    185
    Re: Can't control my spindle speed
    I am trying to install the C11 with the FC350BJ-110 controller. I think i am correct but, do the analog wires postive go to P2 and the negative got to P3. do the 2 connections on the pot need to be connected to a relay?
    Quote Originally Posted by Vogavt View Post
    Updated Rev 5.
    Mar 2007
    2083
    Hi Truckiec
    P3 is the negative connection to the potentiometer and / or C11 analogue output
    if you want to have the spindle speed control via the C11 or manual speed control control using the potentiometer
    you need a switch (or relay ) to connect the FC350 P2 terminal to the potentiometer P2 terminal for manual speed control or
    FC350 P2 terminal to the C11 analoge 0-10V output for the computer to control the speed
    Do you have a link to the diagram showing how you intend to connect the relay ?
    John
    PS
    for FC350 repair information try
    http://timsmachines.com/wp-content/u...viceManual.pdf
    Aug 2016
    185
    Quote Originally Posted by john-100 View Post
    Hi Truckiec
    John
    PS
    That is what it thought. So to clarify, the negative of the C11 analogue voltage goes to P2 and the 0-10 volts to P2.
    What do i need to do with the switch on the pot. That switch resets the board. So where have you guys been connecting that. Is there a relay on the C11 that can act as the switch?
    Sent from my XT1635-01 using Tapatalk
    Aug 2016
    185
    Ok been awhile since i could get back to this but here is where I am and if anybody can shed light on this would be great. I know I am probably missing something simple or I have a board issue one.
    So here is what I have done ...
    I have my C11G working with everything Charge Pump, XYZ axis running, Limit switch, ESTOP,Index and probe all working. The only thing left is my spindle.
    I have connected a isolated external wall wart power supply 12Volts to the ANALOG 12V in and ground. I have wire from the 0-10 Volt out and the shared ground going to a aviation connector. I am hanging my Volt/Ohm meter on the Aviation connector. In MACH3: Under motor outputs I have spindle checked and using pins Step-14 and Direction 16. In spindle control i have use relays off, use spindle motor and step/direction checked. In pulleys is set pulley 1 to 0 min 5000 max. I have steps per set to 1000 and velocity to 1500. I have played around with step pulse and dir pulse duration and the pot on the c11G board. When I turn on using M3 command OR just click start spindle and set to say s2000 i get no analog output. I know i have 12 v going in but getting basically zero out...
    Any ideas?
    Hi Truckiec
    John
    PS
    Aug 2016
    185
    I wanted to see if anybody could answer a couple questions. I am using the C11G and I do have spindle control, BUT! Here is the rub, I am using relay3 for coolant control and I am using relay2 for my spindle light. Arturo sent me a way to jumper the board to do this.
    I started off with a 12 vdc supply to power the analog side. I was only getting 9vdc out. Now here's the first question... I am seeing different voltages listed for this board. 0-10, 0-7 but when i read across p1/p3 i have 12 vdc. So Artuo told me to get a 15vdc supply. I have that supply in and do get 12vdc out to P2. But now whenever the C11G board is in estop or whenever its not in green status, relay 2 chatters and is ON. Once the C11G comes to green all is well.
    Artuo says it is a ground issue.
    I have no common between the 15VDC supply and the C11G ground. I was using a PC style power supply to power the C11G, that has common ground between low voltage and AC. I changed this to a isolated supply as well and there is like 12 Meg Ohms between Chassis ground and C11G 5vdc. No common between 36 volt and chassis.
    If i remove the wiring to the P1/P2 the relays stops chattering as well if I remove the input to C11G 15 vdc analog. I am thinking about buying another PWM to 12 volt board to see if this clears it up but I am very frustrated that the C11G wont work...
    Anybody got any ideas. here is pdf of my wiring
    Attachment 418132
  17. #17
    Mar 2007
    2083
    which speed controller have you connected to the C11G analogue out ?
    provided the 15V power suplies output is floating I can't see any thing wrong with your wiring diagran
    John
  18. #18
    Aug 2016
    185
    John
    I have the fc350bj/110v the X2 Harbor Freight Mini Mill.
    I can't see anything wrong with the wiring either. Do you have a circuit for PWM to Analog that I could build.
  19. #19
    Mar 2007
    2083
    looking at your wiring diagram
    I notice you have used a PC power supply for the C11G 5V supply and the 12V coolant relay
Name:	5 & 12V wiring.jpg
    not all PC power supplies regulate the outputs very well with little load or no load on the +5V output
    found this online for your FC350 board
    Attachment 418134
    John
    PS
    a 2 ohm 15W resistor will add a 2.5A load to the 5 V output
    a 6 ohm 25W resistor will add a 2 A load to the 12V output
    Attached Thumbnails Attached Thumbnails 5 & 12V wiring.jpg   5 & 12V wiring.jpg
  20. #20
    Aug 2016
    185
    Attachment 418134
    John
    PS
    Thanks for the info..
    I changed out the pc supply just see if it would cure the issue. The new supply is a 5 vdc wall wart. Still no love..
Page 1 of 2 12
  1. spindle speed control
    By pastoratrestore in forum Phase Converters
    Last Post: 07-19-2013, 11:42 PM
  2. X2 Spindle Speed Control
    By BSawyer486 in forum Benchtop Machines
    Last Post: 10-19-2011, 09:22 AM
  3. Spindle Speed Control
    By bobkeyes in forum Mach Mill
    Last Post: 09-13-2010, 05:43 PM
  4. Spindle speed control
    By Appalachiatools in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 04-18-2009, 01:03 AM
  5. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
    By peter.blais in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2006, 09:29 AM
