Will a later version of EZTRAK software solve my issue?
My EZ TRAK SX came with disc labeled "ver 2.25/4.43". I don't understand what the 2 numbers refer to and I thus I don't know if I have a version 2.x or a 4.x. Not that it matters to me, but apparently, the version I have does not support "POCKET" command. In the MDI screen, the 'up arrow' rectangle is blank = not as described in the manual as "'up arrow' POCKET". Since I could not get into the pocket feature from the MDI screen, I tried creating a PGM file in my PC text editor which included the PATH and POCKET parameters from the example in the manual. The program would not load. When I tried to edit the PATH line in the program at the mill, it changed it to a POCKET program screen that I had never seen before, which described a pocket with zigzag, inout, and border variations (that I could not change from where I was). When I went back to the program list, the PATH line was removed/replaced by the POCKET line - and also would not load. Question is: how to I get to a PATH program line, or the POCKET zigzag, in/out, Border screen from the MDI?
From many posts, it seems it would be foolish to try and install version 6 on my machine - but that is the only version I have seen for sale. Can I buy or scrounge an older (but newer than mine) version that will improve my situation?
Also, Is there a list of EZTRAK program commands somewhere other than in the EZTRAK programming and operation manual?
