I'm running into some trouble trying to activate the "TSC enable" parameter on one of my machines. The bit was disabled accidentially, but it won't activate when I try to re-enable it. I have the setting for parameter lock disabled and the e-stop is active....when I punch in "1" then hit enter, the typed-in number disappears but the parameter remains at zero.
I called the HFO briefly but was away from the machine at the time. The phone tech said TSC doesn't require an activation code, so I'm wondering if there's some other hardware parameter that needs to be altered in order to recognise the option. The control alarms out when I try to execute an M88 command, and the "aux coolant" button of course doesn't do anything.
I went over to a different machine that doesn't have TSC hardware, and it does indeed let me toggle the parameter either direction. hmmm why does the other machine not want to cooperate...
Has anyone ran into this before?
