603,943 active members*
3,384 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Can't find C5 and C7 (PicStep component)
Results 1 to 4 of 4
    Apr 2005
    35
    I am in the process of building my first PicStep and I have come across a problem I didn't anticipate. I can not for the life of me find a 1uF 100V MKT capacitor or at least not one that fits
    I did find this one and bought it
    http://www.mouser.com/search/product...ualkey58110000
    Unfortunitely I failed to check the physical size of the component. Since then I have looked quite a bit at Mouser and Digikey but have been unable to find on that is this size (approx. 3" or 7.5mm)
    If anyone can point me in the right direction I would really appreciate it. What has everyone else used?
    Thanks,
    John W
    http://home.comcast.net/~pwprojects
    Dec 2005
    The recomended capacitor (data sheet) is a 1uf mono. ceramic or you can use a 1uf electro. as used in Embedded Acquisistion Systems design
    Apr 2005
    35
    Forgive my ignorance but is an MKT capacitor the same thing as a "mono. ceramic"?
    As you may guess I am not very electronics literate but it is facinating...
    Thanks,
    John W
    Dec 2005
    MKT capacitors are miniature polyester and monolithic ceramic are minature multilayer ceramic capacitors.
    I have used ceramics on my picstep boards. I suggest you do some research on the net (google) if you want to go into the depths of capacitor properties
    David
