I must have deleted the box to rereiw the post before saving it. Where do I go so I can read it?
Thanks.
Thanks.
Do you refer to the Code generated by the system? There are a few things you need to check, is the Post manager pinned or docked to the side of the window? You can tell if this is the case because you will see "Layer-UCS-Post Manager" laid out vertically on one side of the window. If it is not pinned or docked it is closed and you will need to turn it back on using the following steps.
Right click on a Toolbar and left click on Layer-UCS-Post Manager. That should put a Check next to the "Layer-UCS-Post Manager" option in the menu and it will appear on the left side of the window. When you shoose the post option it should be populated with code.
Regards,
Right chick on the top of the data cam tree manager.
And select the layer-ucs-post manager.
John
Thank you very much, that's what I was looking for.
Thank Chad.
