587,163 active members*
3,722 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Can't find this tool to measure the I.D. of tubes anywhere..
Results 1 to 11 of 11
    May 2007
    320
    Exclamation Can't find this tool to measure the I.D. of tubes anywhere..
    Okay I am looking for a tool like what I have drawn up in my attached photo. Does anybody make a tool like this already or know where I could have one made, etc.?
    I need to measure the I.D. of plastic tubes used in say hand creams, toothpaste, etc. before the tubes are sealed closed. As we all know these tubes are very flexible plastic so holding them in round perfectly is not very easy. And for any tube sizes bigger than 1" in I.D. I do NOT have PIN gages that big.. my pin gages only go up to 1" in O.D.
    Thanks all!
    Aug 2009
    684
    Looks like a Bowers Gauge (but they are three-pronged...)
    Could you measure with a Bowers Gauge if the tube was supported externally with a ring gauge? Or make your own stepped plug gauges?
    DP
    Mar 2003
    4826
    Could you make your own gauge? Something similar to a unibit step drill, but without the gash for a cutting edge. Just get somebody with a cnc lathe to whip up a few. You could specify whatever step you can live with at each diameter. Laser mark the diameter on each step.
    First you get good, then you get fast. Then grouchiness sets in.
    Dec 2006
    447
    How about rolling up some shim stock, plastic or metal, inserting it into your tube, let it expand, mark the position of the inside edge, and do the circumference math backwards.
    Vern
    May 2007
    320
    step gages or plug gages will not work within my budget.. I need to be able to measure tube I.D.s from 1" I.D. up to 3" I.D. in .002" increments and accuracy. We would be talking 1000 different 'steps' on a taper gage or go-no go gages.. that would cost a FORTUNE and mean a LOT of different tools around. So I need something that is adjustable to handle a specific I.D. range.. maybe a tool that could do .5" in one tool... so that would mean I would need 4 total tools.
    remember it has to keep the flexible plastic tube in PERFECT round while measuring the I.D. down to an accuracy of .002". The I.D. measurment must take place about 1" INTO the tube from the open end.. so the tool must be able to go INSIDE the tube and expand or contract it's measuring size range.
    Jun 2006
    440
    I think you are still going to end up with a lot of tools looking at what your drawing was suggesting. If your tool expands .5" it will end up with gaps between the pie wedges that are going to distort the tubes as they expand. Depending on the material you're measuring then before you had enough positive force to cause a ratcheting thumb knob to slip then the material will have distorted enough to cause your circle to have flats between the pie wedges. Relying on feel and a slip fit isn't going to be very accurate or repeatable with material that distorts easily. Either way your not going to be able to hold your .002 resolution on easily distorted material
    If destructive testing is allowed then you could rig a fixture to hold a section of the tube then take a spline measurement of the circumference using a CMM to get an accurate measurement. You could hold it out of round and still get an accurate circumference and then you can easily calculate your diameter. For a fixture you could convert a small tool makers vise, two pins on the fixed jaw and one on the movable centered between the others. Slip a ring of material on the pins and open the vise until the material is taught, preferably using a torque wrench set to below the amount of pressure that is required to stretch your material being measured. Then simply take a few points from each pin and return to the first pin to get a spline length. Divide the spline length by 3.1416 to get your ID measurement.
    A capability study would tell you how frequently you'd need to repeat your procedure to maintain the tolerance range you have.
    Quote Originally Posted by squale View Post
    Suppose you were an idiot and suppose you were a member of Congress. But I repeat myself.
    Mark Twain
    Mar 2003
    4826
    Or instead of stretching it with pins, just squash the tube flat and measure across the maximum length on the OD. Two times this length plus 2PiR - 2R = circumference of the tube OD, where R = the wall thickness of the tube, which is probably easily gauged with a dial guage.
    I'd try this on a known sample (measured with a plug gauge) to begin with, to determine how accurate the formula is due to unintentional stretching of the sample.
    Aug 2009
    684
    Have used dental wax in the past to take impressions of features for measurement purposes. What about filling the tube with the stuff, let it harden then pull it out and measure the OD?
    DP
    Dec 2008
    226
    use the flexibility to your advantage. take two semicircles 3/Pi inch in diameter (gives a circumference of 3 inches for convenience, just under 1 inch in diameter) attached to a caliper. Spread the caliper in the flexible tube, add twice the measurement to the 3 inches and have a cheap calculator nearby, divide by Pi. Get a programmable calc and just enter your measure and it gives your diameter. Or if your willing to spend a few bucks, program a pic to read a digital calipers output and display the diameter!!
    Jan 2010
    34
    if you have a 4 jaw chuck you can mount two pins , one opposite of each other, place your tube over the two pins and open one jaw until your tube will not slide over pins freely then remove tube and measure over your pins.
    Mar 2003
    927
    Bowers could make you a special anvil with a dozen fingers or more, (instead of the normal three),to do what you need ..
    Or several anvils to cover your range, as I doubt one would have enough range.
    Keep in mind that one reader head would probably fit all the anvils..so one head could be used for multiple anvils..Unless you need to have all of the sizes in service at the same time..
    Bower is serviced and sold by Folwer in the US..
    http://www.bowersmetrology.com/
  1. Need to find Acroloc tool holders?
    By glengeniii in forum CNC Tooling
    Last Post: 10-06-2011, 01:21 PM
  2. Hit Tool Offset Measure by accident
    By BBQ70 in forum Haas Mills
    Last Post: 12-02-2010, 03:41 AM
  3. Offset, measure the first tool and second tool
    By domax in forum Daewoo/Doosan
    Last Post: 12-30-2009, 05:20 AM
  4. Help To Find Online Tool Shop
    By Brenck in forum MetalWork Discussion
    Last Post: 01-27-2007, 05:12 PM
  5. RFQ: 8mm tubes
    By JustinM in forum Employment Opportunity
    Last Post: 09-06-2006, 06:53 PM
